Blind Billy
Can't open PDFs using IE 10
Apr 23, 2013 2:24 PM
Tags: #ie #open_pdf #reader_11
I can still open PDFs I receive as an e-mail attachment.  But suddenly I can no longer open PDFs using IE 10, such as those I find links to after a Google search.  I am using Reader 11.0.02 and IE 10.0.9200.165400.  The failed attempts result in a blank white page with a small box with an "x" inside in the extreme upper left of the blank page.  I've tried Google search troubleshooting.  Made sure that the IE add-on for PDFs was enabled.  Any ideas, other than downloading Firefox?
    Apr 23, 2013 2:47 PM   in reply to Blind Billy
    Try to repair the installation of Reader or uninstall Reader, then re-install.
    Apr 23, 2013 6:43 PM   in reply to Blind Billy
    Apr 24, 2013 9:44 PM   in reply to Blind Billy
    First let me tell you that I do not have any problems viewing online PDF docs in IE10 on Windows 7, for example http://helpx.adobe.com/pdf/adobe_reader_reference.pdf
    I do not know what is causing your problems, but I am getting a little bit suspicious by your adventure on downloading Firefox.  Are you sure that your system is free of malware?  Firefox will never do any of the things that you described.
    Apr 24, 2013 11:54 PM   in reply to Blind Billy
    Glad you got it sorted.
    Regarding the IE10 update, you can prevent that in future by http://www.microsoft.com/en-us/download/details.aspx?id=36512
    Aug 1, 2013 10:11 AM   in reply to Pat Willener
    I have the same problem on a machine.
    It only occurs for 1 user however.
    If you login as a different user, the problem does not occur.
    Disabling the add-on does not force it to open outside the browser either.
    Re-installing adobe reader 11 doesn't fix it either.
    Aug 11, 2013 5:44 PM   in reply to Blind Billy
    Blind Billy, I could hug you right now!!  I had the exact same experience you described above.  After working on this issue for countless hours, I was about ready to simply buy a new computer! I finally just uninstalled Internet Explorer 10 and BINGO! I can now read all the .pdf files online that I need to be able to see.
    Thanks for taking the time to explain how you fixed the problem.  I'd love to go back to IE10, but I have to be able to see the .pdf files online.
    Thank you!
    Aug 15, 2013 2:05 PM   in reply to treechaser4ever
    The REAL Fix for this issue!  I've been fighting this for months and finally found the answer and a reasonable explanation!
    http://superuser.com/questions/561036/unable-to-open-ie-10-in-32-bit-m ode
    From the article,
    "This occurs because the TabProcGrowth registry entry is set to 0, meaning tabs are set to run in the same process as the manager process (64-bit), rather than opening a new process for each tab (32-bit). You can fix this by changing the registry entry here:
    HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\TabProcGrowth
    Set it to something greater than 0, restart IE, and you should see normal behavior resume (and your add-ons should work again). "
    Aug 15, 2013 9:00 PM   in reply to Thomas Amann
    Thanks Thomas. This worked for me. I searched for days for a real fix!!!
    Sep 10, 2013 3:19 PM   in reply to Thomas Amann
    Thanks Thomas! Your answer worked for us as well. This has been a common problem and fixing the registry was the only thing that worked. Much appreciated.
