jaychristie909
Why can't I make a project progressive?
Apr 23, 2013 3:06 PM
Tags: #error #adobe #settings #sequence #encore #dvd #fields #progressive #interlaced
When I open a new project in Encore, I want to set it to progressive. But no matter what I try, the Video Transcoding settings are greyed out and I can't change it from Lower Fields First. This has left me with jumpy videos, and I have no idea how to correct it. I've tried googling for solutions but this doesn't seem to be a widespread issue, so I'm guessing I've missed something. Can anybody help? Any advice would be appreciated.
    Apr 23, 2013 3:25 PM   in reply to jaychristie909
    Export from Premiere with the desired settings for mpeg2-dvd.
    Import the two files into Encore.
    Encore will  be set to Don't Transcode for the files.
    Make menu and burn.
    That should do the trick.
    Apr 26, 2013 10:39 AM   in reply to jaychristie909
    If your original footage is interlaced, you should burn it that way.  This will not cause jumping.  If you see that in the final DVD, something else is amiss.
