bonniebp
I have the premier elements 3.0 version.  I have been using it successfully for years and have never
Apr 23, 2013 5:58 PM
I have been using it for years with success.  Recently I had a proplem with opening the program.  I brought it to Best Buy.  They fixed it and I can make the movies but I can not burn a DVD.  I get a message, " cannot initialize  the DVD burner engine".  Can you help me.
    Apr 23, 2013 7:30 PM   in reply to bonniebp
    bonniebp
    In those years of success with Premiere Elements 3/3.0.2 what was your computer operating system and what is your computer operating system now, same or different? What did Best Buy say that it did to correct your Premiere Elements and/or computer problems.
    Did you have the 3.0.2 Update installed before and after you had Best Buy correct problems for you?
    Can you burn to folder with the program as it is now? Depending on your answer to the latter, is the burner firmware up to date and such. If you can burn to folder, can you then burn to DVD using the VIDEO_TS from the burn to folder and a program such as ImgBurn and your current DVD/CD burner?
    ATR
    Apr 23, 2013 8:04 PM   in reply to bonniebp
    That MAY be related to the information in the links below
    These notes are (mostly) for Encore, but since the disc burning module inside Premiere Elements is also licensed from Roxio, the steps and ideas are the same for PE
    As well as the below, right click the program icon and select Run as Administrator, which is NOT the same thing as running the computer with the Administrator account, and which fixes several "odd" problems... To create a two layer DVD (or a BluRay?), you MUST have Encore set to use the Run as Administrator option
    Run as Administrator http://forums.adobe.com/thread/969395
    -and Vista http://forums.adobe.com/thread/1021721
    Odd Errors http://forums.adobe.com/thread/670174
    Long File Names or odd characters cause problems
    Read http://forums.adobe.com/thread/588273
    And #4 http://forums.adobe.com/thread/666558
    And This Message Thread http://forums.adobe.com/thread/665641
    Things and Software to AVOID when authoring/burning a disc... says Encore, but also applies to Premiere Elements and disc burning
    Start --> http://forums.adobe.com/thread/608660
    #2 has WHY Explained http://forums.adobe.com/thread/607390
    Plus http://forums.adobe.com/thread/562941
    Create a DVD output ISO file (Encore) or set your DVD output to a folder on your hard drive (Encore or Premiere Elements) and then use the FREE http://www.imgburn.com/index.php?act=download to write files or folders or ISO to disc for DVD or BluRay (send the author a PayPal donation if you like his program)
    Apr 24, 2013 5:48 AM   in reply to bonniebp
    bonniebp
    Thanks for the follow up. Great News.
    Good work you and John T. Smith.
    Continued success.
    ATR
    Apr 24, 2013 6:26 AM   in reply to bonniebp
    It is most likely that Best Buy downloaded and installed the latest video driver for you chip/card. Having an obsolete video driver is a major cause for PrE failing to launch.
    The "Run as Administrator" bypasses some Windows User security measures, that can come into play, if one is logging onto Windows with less than an Administrator Account. Their account maybe have Administrative Privileges, but that is not quite the same as being an Administrator. It just depends on the exact settings in the log-in account.
    We see the failure to burn a DVD (especially a DL DVD-Video) often in Adobe Encore, which is a full-featured authoring application, that ships and installs with Premiere Pro. The Run as Administrator normally fixes that. Now, it might seem odd that the same fix would work for Adobe Encore, and Premiere Elements, but both programs use the Sonic AuthorCore DVD/BD authoring modules. What we see is an abstraction layer in Encore and PrE, that runs the Sonic AuthorCore modules behind the scenes, so there are some similarities.
    The good news is that you now have that computer up and running. If you have not updated PrE 3.0 (one update offered, and I think that it is listed as 3.0.1?), I would do that. The update fixed some compatibility issues with PrE 3.0 and Vista, which was released just after PrE 3.0 was.
    Good luck, and happy editing,
    Apr 24, 2013 7:11 AM   in reply to bonniebp
    I would look here: http://www.adobe.com/support/downloads/detail.jsp?ftpID=3565
    It appears that I had the point numbers wrong, and the update was 3.0.2.
    Apr 24, 2013 9:08 AM   in reply to bonniebp
    bonniebp
    Back in post #1, I did mention the Premiere Elements 3.0.2 Update, not Update 3.0.1.
    Sorry, that I did not post the link to that Update 3.0.2 when I mentioned it in the earlier post in your thread.
    But, I see that you and Bill Hunt have worked out the detail.
    ATR
