I want to migrate a bunch of documents that are based on an old template to a new template. Is there a simpler and quicker way to do it?
Than what?
Have the old document and the new template open.
File > Import > Formats
Thanks.
When I import the formats, I have both old and new styles in the document. I understand that I need to delete the old styles and manually apply the new styles. Is my understanding correct?
I find applying styles imported through File > Imports > Formats is time-consuming. I am looking for some simpler method.
What I expect is when I delete an old style, I should be able to specify an alternate new style. Is there any option available?
It sounds like you need the Paragraph Tools plugin ($10) from
http://www.siliconprairiesoftware.com/.
<http://www.siliconprairiesoftware.com/>
There is also TemplateMapper, much more expensive, but with more
capability at:
http://www.cudspan.net/plugins/executioner.php?do=displayPage&field_tab_num=2
Not too time-consuming, though more so than using nifty third-party tools … corporate policies forbid such frivolities here, so I have to do everything the hard way ;-}
N
You could also use Rick Quatro's FindChangeSpecial plugin:
http://www.frameexpert.com/plugins/findchangespecial/index.htm
He also has a batch version of it to change a list of formats.
Best regards
Winfried
