Form Label Text-Align Center
Apr 24, 2013 8:30 AM
I am having troubles aligning the label of my form to center. When the page loads, it looks like it wants to be center aligned, but then aligns to the left. I can't tell which CSS is making it do this. Would you be able to help me narrow it down?
link is http://www.thelightingpower.com/donate-now
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Apr 24, 2013 9:19 AM   in reply to designNMP
    That is because of the attribute position: absolute; that gets added at runtime with your jQuery custom function.
    To fix, Find this in your custom.js file:
    $('textarea').each(function() {
    if( $(this).val() == ''){
    $("label[for="+$(this).attr("id")+"]").css( "position", "absolute" ).css("z-index", "2");
    }else{
    $("label[for="+$(this).attr("id")+"]").hide('slide', 'fast');
    And replace that chunk of code with this:
    $("label[for="+$(this).attr("id")+"]").css("z-index", "2");
    }else{
    Apr 24, 2013 9:58 AM   in reply to designNMP
    Remove the text align center atribute from style.css (line 664) and center the table
    table td {
        padding: 10px 5px;
        text-align: center;
    Oct 15, 2010
    Apr 24, 2013 10:31 AM   in reply to designNMP
    In the code you originally have in your custom.js file, try changing 'absolute' to 'relative' to see if the label gets centered along with the input box. If it does, that is definitely the culprit. Maybe you could actually stick to 'relative' instead of fully removing it - as you said that didn't work earlier.
    $("label[for="+$(this).attr("id")+"]").css( "position", "relative" ).css("z-index", "2");
    }else{
    Apr 26, 2013 9:46 AM   in reply to designNMP
    I dont know why it is happening but I can tell you the source of the problem is the js file below. If you  comment it out like below the text is centered.
    <!-- <script type="text/javascript" src="http://www.thelightingpower.com/js/video.js"></script>-->
    Apr 26, 2013 9:45 AM   in reply to designNMP
    designNMP wrote:
    Thank you for your replies. Both of them did not work...not sure where the text-align: left is coming from. If you have any other ideas, I would greatly appreciate them.
    For me the label text is jumping to the right not the left?
    Apr 26, 2013 1:57 PM   in reply to designNMP
    Did you miss my reply above?
