Skifclif
Creating a rectangular marquee to select objects
Apr 24, 2013 9:24 AM
I am trying to use the selection tool or the direct selection tool to create a rectangular marquee somewhere within the boundaries of an illustration.
I want to select only those objects that are fully or partially within that marquee.
I can use the lasso to select objects in this way.
But if I try to use the selection or direct selection tool, it selects and moves the first object I touch.
I can use the selection tools and begin from outside the image area and create a rectangular marquee of selected objects.
But I can't do this if I begin within the image.
    Apr 24, 2013 9:47 AM   in reply to Skifclif
    Oultline View allows you to start dragging inside a shape, Ctrl+Y to toggle between Regular View (Preview) and Outline View
    Apr 24, 2013 9:48 AM   in reply to Skifclif
    The only way to prevent selecting the first object you click on is to lock it or move it to a different layer which can be locked or hidden. Of course, the same goes for anything else that's within the marquee-select  area, but to be exlcuded. It's always useful to divide up your elements (on layers) in relational ways to facilitate such manipulations throughout the project. Often you can anticipate, other times you have to adapt on the fly.
    Apr 24, 2013 9:52 AM   in reply to Skifclif
    Obviously if you use a selection tool you will select and move the first object you touch if it is filled.
    That’s the way it’s supposed to work under normal conditions.
    However you may (1) switch to Outline mode (Cmd+Y)
    or (2) check ‘Object Selection by Path Only’ in Selection & Anchor Display preferences.
    Using either of these you can marquee select without having the fill of an object affect your selection.
    Apr 24, 2013 10:06 AM   in reply to Skifclif
    Illustrator is mostly alone in its selection options. Some other vector drawing applications have an option as to the marquee selection behavior.
    I wouldn't hold your breath for a change.
    Mike
