kat_k-f
Problem with CS3 installation. Update Check doesn't accept serial number
Apr 24, 2013 11:46 AM
Tags: #cs3 #mac #update #software #uninstall #failed #deactivation #installation-problem #installation_serial
Hey,
I have CS3 which I need to instal from one mac to another. It already has been deactivated and installed again as well. But after entering serial number I can see window called Updade Check and here my serial doesn't work. Technical support does not longer support old versions so they can't help me. But I need to run CS3 on this mac anyway. Can I skip Update Check step anyhow? Or what can I do to run this? Problem is I already cannot even use it on previous machine 'cause it already has been deactivated.
Does anyone know what should I do in this situation?
  • kglad
    Jul 21, 2002
    Apr 24, 2013 11:49 AM   in reply to kat_k-f
    skip the update check.
    you can update each program directly after installing and activating, if you need.
  • kglad
    Jul 21, 2002
    Apr 24, 2013 12:47 PM   in reply to kat_k-f
    you're welcome.
