csvideo
Export Files - which is highest quality?
Apr 24, 2013 1:38 PM
Tags: #export_files
I am using PRE 11
I normally start a new project for each event that I shoot.  Like a birthday party, or soccer game, etc.  I do the editing, adding some stills, transitions and titles, etc.  Then I export the video to a file which I will later use in a "master" project.  I always create AVCHD disk for myself and some DVD's for family and friends that cannot play AVCHD.  So I accumulate my  exported files until I have close to the 4.7 GB of video that will fill a AVCHD disk.  I put these files into a master project, add a disk menu and burn.
I notice that pre11 has many options for exporting.  I choose "computer" then choose AVCHD.  the available outputs include several m2ts chioces and several MP4 choices.  I notice that with m2ts, there is a 1920 X 1080i 30 fps, and a 1920 X 1080P 24 fps.  I would think that p is better than i, but I would think that I should use 30 fps.  Also available is MP4 1920 X 1080p 30 fps.  Maybe that one is the best.
Please advise me on this.  For what I am doing, which is the best type of file.  I want the best quality I  can get.
    Apr 24, 2013 1:44 PM   in reply to csvideo
    For outputting a file, that I will later re-edit, or otherwise use in another program, I really like one of the Lossless CODEC's, like Lagarith, or UT. This article goes into more detail: http://forums.adobe.com/message/4556586#4556586
    The downside is that those files, while compressed, are still fairly large, but with no visual loss in quality, and that if THOSE files are delivered to another person, they would need the correct Lossless CODEC on their machine, to work with them. As both Lagarith and UT are free, that is less of a problem.
    Apr 25, 2013 5:28 AM   in reply to csvideo
    As Bill says, it depends on how and where you're going to use the file.
    Are you going to use it another high-def or standard definition video project? Are you going to use it to create a DVD or BluRay? Are you going to post it to YouTube or Vimeo -- or use it on your own web site? Are you going to play it on a computer or an iPad?
    Each  medium has an optimized format. And, if you use the wrong output in the wrong place, it may look great but be totally unplayable.
    Apr 25, 2013 8:14 AM   in reply to csvideo
    It would be better to choose a file format that's optimized for BluRay playback.
    And, of course, ensure that your disc player is capable of playing a raw AVCHD file in addition to a standard BluRay file. In other words, a standard DVD player won't do it and neither will a number of BluRay disc players.
    That said -- and since it appears you're going to burn your AVCHD files onto a 4.7 gig DVD rather than a BluRay disc -- just use Share/Disc/AVCHD. There's no reason to make it any more complicated than that.
    Apr 25, 2013 8:25 AM   in reply to csvideo
    csvideo wrote:
    My finat objective is to end up with an AVCHD disk that I play on my blu-ray player for my hi def TV.  This is about 4.7 GB and 20 minutes of video.  So I create a pre11 project for each event like a party, etc.  Then when I have enough events to fill a AVCHD disk, I make a video file (share) for each event and then put these files into another "master" pre11 project.  Then I make a disk menu and burn.
    I want to choose the file that will have the least loss of quality.  The highest resolution seems to be 1920 X 1080.  The mp4 format offers a 1920 x 1080p with 30 fps.  That seems to me to be the best if I am correct in assuming that p is better than i and 30 fps is better than 24 or 25.  the m2ts format doesn't offer these options.
    I was working a similar approach a month or so ago.  Bill Hunt wrote about a lossless codec called Lagarith.  I found it, downloaded it and tried it.  It works perfectly except that the file size is enormous.
    The rest of the answer to you question seems to be on the screen.   Notice that Adobe labels "AVI"  as "For Use in Editing in Premier Elements".  Pressing the Advanced button provides several codecs.  The default NTSC is 720 by 480, which is unchangeable and  I don't think would work well if you are working with AVCHD.  (I don't think you said where the source files came from.)  The "Uncompressed UYVY" would interest me because is  uncompressed and you can change to 1080.   I think you will have to do some testing and see what ends up looking good on your viewing system.
    An entirely different approach is to use cuts and pastes from one project to another.  In another thread the subject came up and the poster found a solution in software called "Spartan Lite".  I found it on CNET for free download.  The poster in that thread said he was successful pasting clips from the timeline in one project to the timeline in another.  I have not tried it yet, but it might be what you are looking for.
    Apr 25, 2013 8:29 AM   in reply to csvideo
    Cliff,
    You are faced with the same dilemma, that all editors face, from time to time.
    Here is how I would handle it (and have for many Projects):
    1. From your completed Project(s), author the AVCHD DVD disc, for delivery.
    2. Author a DVD-Video disc, if necessary, for those clients/recipients, who cannot handle the AVCHD material, which requires a BD player.
    3. Then, output that/those Timeline(s) to either Lagarith, or UT Lossless (in an AVI wrapper), to be used in later Projects. As you will need to download, and install the Lagarith, or UT Lossless onto your computer, that/those output file(s), will play, Import and edit perfectly. Those files will be used by you, for later editing/re-editing, but will not be useful to others, unless they also download and install the necessary CODEC, but they will have received the AVCHD DVD disc, or the DVD-Video disc, so should not have a need for those output files.
    It does mean several output sessions, but covers almost all bases, and IMHO is worth the effort. The reason for the output to a visually lossless CODEC is to keep additional compression steps out of the workflow. You are starting with fairly heavily-compressed MTS files, to begin with, and for output to AVCHD DVD discs, or to DVD-Video, will need to recompress again. Working with the Lagarith, or UT Lossless files, keeps you from doing yet another compression step.
    Apr 25, 2013 8:42 AM   in reply to Bill Hunt
    Seriously, CS. Just try my way. This tool is designed to create the very file you're trying to create!
    Apr 25, 2013 8:48 AM   in reply to whsprague
    Bill,
    You are correct - either Lagarith, or UT Lossless DO result in large files, but they are smaller than Uncompressed, and like Uncompressed, are visually lossless. Because they do employ compression, they yield smaller files - though not THAT much smaller.
    For SD material, the DV-AVI files are usually just fine, until one has several generations. The DV/DVC CODEC employs ~ 5% compression, and while "good," is not visually lossless - still good.
    With most other CODEC's, there will be compression, and visual loss, with each generation. Some, like H.264, are very, very good, but start falling apart, with multi-generational compression. Use them once, or maybe twice, and things still look pretty good - use them 3 - 4x, and I feel that they begin to loose quality, and especially where there is any rapid movement, with either the subject, or the camera.
    I like those two Lossless CODEC's, because I feel that they split quality vs compression, i.e. file size. Going way back, I realized that video files ARE large, so have always invested heavily in HDD real estate, and just live with large files. When it comes to editing, or re-editing, file size is not necessarily indicative of editing time. If one has ever Imported and edited a large DV-AVI file, in any flavor of Premiere, and then tried that with a much smaller WMV file, they would know that file size does not always, and directly relate to editing time - that large DV-AVI will be smooth, easy and efficient, while the smaller WMV will take more time, and many more resources, even if their Duration is the exact same. The only downside to the DV-AVI is that it does take more HDD real estate.
    Just my personal observations,
    Apr 25, 2013 10:53 AM   in reply to csvideo
    In that workflow, you have two: the initial compression in camera, then the final compression for final delivery. There is no way around those compression generations, unless one used a CODEC for the final, that did not compress, and with DVD-Video, BD, and most other output options, one cannot get around some level of compression.
    The intermediate files, if one uses either a Lossless CODEC, or Uncompressed, will not reduce the visual quality, in any way, thus saving one compression generation.
    Apr 25, 2013 12:47 PM   in reply to csvideo
    If you start with compressed material (first generation of compression), then output to a compressed format (second generation of compression), and finally re-edit that, outputting to any compressed format, such as H.264 or MPEG-2 HD, or MPEG-2 DVD, that material has been compressed through three generations. Each compression reduces quality, though depending on the footage, that might, or might not be that obvious.
    Apr 25, 2013 4:36 PM   in reply to Bill Hunt
    I'm working on a test of the various ways to do this.  I hope to get the result posted to Vimeo by tommorrow.  I'm using a short AVCHD 1080p60 clip.  So far, the "Uncompressed UYVY" didn't work very well.  The Lagarith worked very well.
    Bill
    Apr 26, 2013 7:22 AM   in reply to csvideo
    Vimeo is an AV file display service, sort of like YouTube, but many feel that the re-encoding for display, is better in Vimeo, than YouTube.
    Good luck, and I will follow, until this coming Monday, when I leave town for two weeks. I will pick it back up, when I return.
    Apr 26, 2013 10:07 AM   in reply to csvideo
    The point of the test was to determine a method and the feasibility of combining smaller projects into a larger project using various file formats used for output by Premier Elements 11.
    Premier Elements suggests through the menu structure that Publish&Share > Computer > AVI is to be used for “Editing in Premier Elements”. The defaults appear to be intended for Standard Definition (SD).  I suspect everything would work well for an SD DVD.
    However, with High Definition (HD) original footage and wanting to preserve the HD quality for AVCHD Disks, Blu-Ray disks or direct playback there may be other choices.  I started with an AVCHD 1080p60 clip taken in Canyonlands NP.  There is a fine textured bush blowing in the wind, tilting (vertical panning) and some serious scenery.  1080p60 is the highest quality setting available in the current, common cameras.
    My method was to Publish&Share the original clip three ways and then combine all four in a single video.  Watching that video should show quality differences.  The first two are “lossless” or “uncompressed” meaning the original should be duplicated in the highest quality.  The third is done using an H.264 codec that has compression and theoretical loss.  In other words, there is “triple” processing.  First the camera itself saves the file, then Premier Elements processes for output to the “intermediate file” and finally that file is processed again for the final file.
    The first process was an AVI Uncompressed codec built into PrE.  The second was a shareware AVI codec called Lagarith and the third was with a AVCHD codec included in PrE 11.  Each clip in the video is labeled. The biggest file was the Uncompressed UYVY, second was the Lagarity and the most efficient file is the AVCHD H.264, which is abou the same file size as the original.
    In each intermediate file I kept the 1920x1080 and 59.94fps settings to match the original.  The project settings were crated by adding the original clip and I confirmed they matched.
    You can view or download the original clip taken directly from the camera here:  https://vimeo.com/64887382
    You can view the 4 clip product here:  https://vimeo.com/64898520
    What differences do you see?  Are they significant?
    Bill S
    Apr 26, 2013 10:10 AM   in reply to csvideo
    Uncheck the chain icon.
    Then you can change it to 1920x1080.
    Square pixel and upper field as the original is upper also.
    Apr 26, 2013 10:16 AM   in reply to csvideo
    csvideo wrote:
    Am I doing something wrong?
    The numbers can be set to 1920x1080 if you press the unlock button to the right.
    I'm not sure the output of a Lagarith file is intended for direct viewing.  Whatever playback software you use may struggle with it.  It's purpose (I think) is to be an "ingrediant" in another project.
    If you watch what I did for the test, it seems to confirm what you find.  The third clip is AVCHD MP4 and seems to have equal visual quality on my computer.  Vimeo specs and processing compress the structure.  For my own purposes I created an additional file at the highest settings I could to view on my computer.  The results appear to be about what you can see on Vimeo.
    Bill
    Apr 26, 2013 4:10 PM   in reply to csvideo
    I'll watch your clips as soon as my computer gets done with a big upload task.
    You would think we would not be testing this stuff.  But, oddly, full AVCHD functionality on the consumer level is new.  This is true for both hardware and software.  An AVCHD 1080p60 camera in the hands of a consumer was pioneer territory only two years ago.  Full support for AVCHD that included the 1080p60 format was not included in consumer software from Adobe or Sony until less than a year ago.
    Blu-Ray players and HD TVs have become common.  But, homemade material to play on them requires a unique collection of relatively new tools and techniques.
    Based on advice from people that have been doing this for years, I fully expected a strong visually detectable difference between the "lossless" and the "lossy" methods.  Results did not match expectations.  Based on the "eyeball" experience, the AVCHD method is as good or better than the lossless Lagarith method.  And, as a bonus, the file sizes are far more manageable.
    I was surprised and learned a lot by trying this.  Thanks for the excuse to do it!
    Bill
    Apr 27, 2013 7:23 AM   in reply to csvideo
    csvideo wrote:
    I ran a similar test and concluded that the lossless AVI is inferior to the h264 avchd file.  I uploaded my stuff to google docs and you can see the difference.  I took part of a project that I have been working on.  I exported it to both AVCHD and to the lossless lagareth AVI.  Then I imported both of those into a new pre 11 project.  Then I exported that to another avche file for uploading.  You can watch the video and see that the avi method (second method) is not quite as good.  Then I went in and exported a single frame from each segment.  I used a frame where there was a lot of movement.  If you look at those stills, the AVI is clearly inferior than the AVCHD.  I can't see any advantage in using the AVI at this point even if I didn't mind the fact that the files are 20 times as large as the AVCHD.
    The link is:
    https://drive.google.com/#folders/0B7mqkiWV2BIRZVV5Z3VOUWJCYmM
    Am i missing something?
    I don't think you are missing anything.  We tried doing the same thing two different ways and agree.  Using AVCHD H.264 is efficient and works as an "intermediate" file format.  Theoretically, there is an additional compression cycle but it is not visible in the resulting project.
    According to Vimeo, the number of views on my test is so small, you and I may be the only ones that want to know how to do "intermediate" files!
    Bill S
