• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Setting a condition tag on an element
New Here ,
Apr 25, 2013 Apr 25, 2013
Hi all,
I've got a bunch of XML files that I import to FrameMaker using a custom structured application based on S1000D. I would like to not show some of the data in the XML files in the final FM document, but preferably not remove it. Is there some way to set condition tags on an element using extendscript? Or is there a way to specify it in the EDD for the structured application? Any other suggestions?
Best regards,
Lisbeth
TOPICS
Scripting
Views
991
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate , Apr 25, 2013 Apr 25, 2013
No problem. In the same EDD you can assign a special paragraph format to a title that follows a hidden element, making it stay on the same page instead of moving to the top of the new page.
Votes
Translate
Translate
Advocate ,
Hi Lisbeth,
I am doing this with a couple of files and as I am pragmatic about these things I use the EDD to assign a particular paragraph format to the data I wanted to remove. That paragraph format is set to white font color, 2 pt high with no space above, no space below and 0 pt line space. This effectively removes the content from the visible document.
Getting into automatically applied conditions in FrameMaker might not be the easiest thing to do. My method does not require any scripting.
Kind regards
Jang
Votes
Translate
Translate
Report
Report
New Here ,
Yeah, that would be the easiest thing, if it weren't for the fact that the next element (the title) needs to start on the top of the page. Having the tiny white text on the first page pushes the title to the next page, leaving the first page looking blank.
Votes
Translate
Translate
Report
Report
Advocate ,
Votes
Translate
Translate
Report
Report
New Here ,
I didn't think of that, but yes, it should work. Thanks!
Votes
Translate
Translate
Report
Report
Advocate ,
I always go for the easiest solutions. Makes me save time for fun stuff.
Votes
Translate
Translate
Report
Report
Advisor ,
LATEST
Votes
Translate
Translate
Report
Report
