Dhrune
Mon ordinateur refuse la gravure après encodage (erreur 2131042562) alors qu'il le faisait correctem
Apr 25, 2013 5:50 AM
Mon ordinateur refuse la gravure après encodage (erreur 2131042562) alors qu'il le faisait correctement  il y a quelques mois. Pourquoi?
    Apr 25, 2013 8:16 AM   in reply to Dhrune
    Google Translate "My computer will not burning after encoding (2131042562 error) then he was properly a few months ago. Why?"
    First
    These questions below may be for a different product... but the information you need to supply is the same, for the products you use
    More information needed for someone to help... please click below and provide the requested information
    -Information FAQ http://forums.adobe.com/message/4200840
    Second
    Things and Software to AVOID when authoring/burning a disc... says Encore, but also applies to Premiere Elements and disc burning
    Start --> http://forums.adobe.com/thread/608660
    #2 has WHY Explained http://forums.adobe.com/thread/607390
    Plus http://forums.adobe.com/thread/562941
    Set your DVD output to a folder on your hard drive and then use the FREE
    http://www.imgburn.com/index.php?act=download to write files or folders to disc
    for DVD or BluRay (send the author a PayPal donation if you like his program)
    Apr 25, 2013 11:19 AM   in reply to Dhrune
    Dhrune
    For now, I will respond in English rather than use my limited knowledge of French or use Google Translate to respond in French.
    The answers are in the details and more information is needed to help.
    a. What version of Premiere Elements are you using and on what computer operating system is it running?
    b. Have you tried to open a new project and burn a new Timeline content to DVD-VIDEO on DVD disc? The main thought here is to find out if your current problem is specific to one project, one Timeline, and one burn to disc OR everything. Have you tried a different brand of disc? What DVD disc brand and type have you been using?
    c. Have you inspected your Timeline content for slivers that are leftovers from files that you deleted from the project? To check, expand the Timeline with the - + slider above the Timeline, and look for thin black vertical lines scattered in the Timeline. If you find any, delete them.
    d. Are you sure that you do not have any Stop Marker at the last file on the Timeline?
    e. When you get to the Burn Dialog, just before you hit Burn, what does the Quality Area of the Burn Dialog show for Space Required and Bitrate?
    f. Are you still able to Burn to Folder; whereas you cannot burn to disc?
    There are many other questions, but let us start with these.
    Thank you.
    ATR
