Actionscript 3.0 question
Apr 25, 2013 11:17 AM
Tags: #newbie #flash_cs6 #actionscript3_0
Hi, all
I absolutely do not know Actionscript 3.0 syntax and need to fix this FAST (of course).
I named my instance, and used this code snippet. It works:
thirtyYearFixed.addEventListener(MouseEvent.CLICK, fl_ClickToGoToWebPage_3);
function fl_ClickToGoToWebPage_3(event:MouseEvent):void
    navigateToURL(new URLRequest("http://www.adobe.com"), "_blank");
this is the previous code, actionscript 2.0 which is pulling dynamic data from the xml:
on(release) {
    getURL(clickTAG + "?*", "_blank");
THE QUESTION:
how do I get it to link to the clickTAG, dynamic data (instead of http://www.adobe.com)
tia,
jarnot
  • kglad
    Jul 21, 2002
    Apr 25, 2013 11:52 AM   in reply to jarnot9
    where (or how) is clickTAG in the actionscript 2.0 version.
    once that's converted to as3 (or, if it's already done), use:
        navigateToURL(new URLRequest(clickTAG + "?*", "_blank"));
  • kglad
    Jul 21, 2002
    Apr 25, 2013 2:36 PM   in reply to jarnot9
    if each button is supposed to do the same thing, use:
    thirtyYearFixed.addEventListener (MouseEvent.CLICK, buttonSymbol_click);
    fifteenYearFixed.addEventListener(MouseEvent.CLICK, buttonSymbol_click);
    fiveOneArm.addEventListener(MouseEvent.CLICK, buttonSymbol_click);
    seeMoreRates.addEventListener(MouseEvent.CLICK, buttonSymbol_click);
    buttonMovie.addEventListener(MouseEvent.CLICK, buttonSymbol_click);
    function buttonSymbol_click (evt:MouseEvent):void {
    trace(loaderInfo);
    var clickTAG:String = loaderInfo.parameters.clickTAG;
         // Check for malicious code injections, only use URLs if they begin with http: or https:
         if ((clickTAG.substr(0, 5) == "http:") || (clickTAG.substr(0, 6) == "https:"))
                  var req:URLRequest = new URLRequest(clickTAG);
                  navigateToURL(req, "_blank");
  • kglad
    Jul 21, 2002
    Apr 25, 2013 4:15 PM   in reply to jarnot9
    you're welcome.
    p.s.  there are easier ways to code that (though i wouldn't change now if i were you):
    var stateA:Array = ["AL","AK","AZ","AR","CA","CO",...];
    for(var i:int=0;i<stateA.length;i++){
    stageA[i].addEventListener(MouseEvent.CLICK,onClick);
