Why can't I get my new default stroke & fill to work in my doc?
Apr 25, 2013 2:07 PM
Tags: #cs5.5 #windows #fill #stroke #defaults
I'm using InDesign CS 5.5 for Window & I'm trying to change my default stroke & fill.  In my document I have deselected everything (Shift-Crtl-A), then selected the line tool, then selected a stroke color.  This is what the top of my screen looks like:
When I draw the next line, it's invisible having no color what so ever.  I've tried the same thing with rectangles & setting a fill; I get the same result, invisible objects.
I have been able to change their colors after I draw them, but I'd rather draw the color I want them to start with.
Any hints?
    Apr 25, 2013 9:23 PM   in reply to LeslieInV
    In Mac OS, my Stroke pannel looks like this:
    Make sure you have the weight and type set correctly. Your screen shot shows 1 pixel stroke weight. Mine shows 1 point. I don't do web layouts, so I don't know if this is a factor, but it's something I noticed.
    Apr 26, 2013 7:10 AM   in reply to LeslieInV
    That's because your document is set of for web or device, rather than print.
    Apr 26, 2013 4:27 PM   in reply to LeslieInV
    Nor do I. And it works as expected, here, so see Replace Your Preferences
    May 10, 2013 12:40 PM   in reply to LeslieInV
    Are you sure you are using the shape tools and not the frame tools (the ones with an X in them)? Frame tools always default to no stroke or fill.
    May 10, 2013 2:55 PM   in reply to LeslieInV
    With nothing selected on the page, and the line tool selected in the tool bar, what shows as the default object style for that tool?
    May 16, 2013 11:33 AM   in reply to LeslieInV
    I had the same problem and finally figured it out.
    In object styles I had [None] selected. Once I selected [Basic Graphics Frame] it worked.
    Note: I did not change the style itself, just selected it.
    Then with nothing selected I changed the fill and stroke color to the color I wanted to overprint and used window>attributes and selected overprint fill and overprint stroke.
    Now when I draw a line or a shape it is the color I selected and it overprints! Yay!
