Which sequence preset for .mp4 movies
Apr 25, 2013 4:15 PM
I'm making a compilation video using clips from already existing hollywood movies.  The movies are mostly 720p .mp4's.  Which preset should I select when I start a new sequence?
  • joe bloe premiere
    Dec 6, 2009
    Apr 25, 2013 4:20 PM   in reply to owiseone61755
    Do this to create a sequence that matches your footage:
    How do I choose the right sequence settings?
  • joe bloe premiere
    Dec 6, 2009
    Apr 25, 2013 4:37 PM   in reply to owiseone61755
    When you launch Premiere and create a new Project, it asks you
    if you want to choose from a list of Sequence Presets... just skip that step
    by hitting Cancel, import your media, then do what is shown above.
  • joe bloe premiere
    Dec 6, 2009
    Apr 25, 2013 6:00 PM   in reply to owiseone61755
    So if I load 30 movies into my project but I only want to work with 2-3 minutes from each film.  How can I extract those clips without moving the whole movie into the timeline and cutting it there?
    Take one of these 720p .mp4 files and create a new sequence.
    Then you add the segments from all of the other clips in the preferred
    order to the one sequence you now have created... editing.
    Adobe Premiere Pro Help and tutorials
    http://helpx.adobe.com/premiere-pro/topics.html
    Getting Started with Premiere Pro CS6
    http://www.video2brain.com/en/getting-started-with-premiere-pro
  • joe bloe premiere
    Dec 6, 2009
    Apr 26, 2013 7:19 AM   in reply to owiseone61755
    I don't have segments from the movies.  Just the complete movies. So how do I get all the segments together.
    That's what you do with Premiere.
    You select segments of various clips and put them
    together in a particular order in one Timeline... editing.
    I don't know what the preferred order will be just yet.
    Don't worry... just start pulling together the pieces you want to use.
    You don't need to immediately determine what your preferred order
    or durations will be.  You can easily change it later... nonlinear editing.
    I want to extract all the 2-3 minute clips and get those into the project and then be able to load those onto the timeline and trim what I want.
    Then... do just that.
    Pick out the 2-3 minute segments you might want to use,
    throw them all together on one Timeline, then start figuring
    out what order, what to trim etc.
    Required Reading:
    Adding clips to sequences
  • joe bloe premiere
    Dec 6, 2009
    Apr 26, 2013 8:14 AM   in reply to owiseone61755
    I want them in the project pane window and be able to pull them as needed into the timeline.
    Load them into the Source Monitor, mark in and out points
    to define the segment you want to include in your Timeline,
    then hit 'insert', 'overwrite' or drag them to the Timeline.
    You really should read about
    Also:
