logsarty
Check the dimension when clipping masked
Apr 26, 2013 5:40 AM
Hi friends,
How do i check the final dimension of image or vector graphics when it is clipping masked in illustrator. If I check in transform it is showing the size including the clipping mask.. I just want to check final trim size of the image.. advance thanks for the help..
    Apr 26, 2013 5:49 AM   in reply to logsarty
    Use the group select tool to select just the mask. Then read the dimensions.
    Apr 26, 2013 6:34 AM   in reply to logsarty
    Using the commands in the Select menu you can also select all clipping masks. Their bounding box then should have the dimension you are looking for.
    Apr 26, 2013 2:28 PM   in reply to logsarty
    Which version of Illustrator are you using ?
    Apr 27, 2013 5:03 AM   in reply to logsarty
    I dont find the commands to select all clipping masks in select menu..
    Select>Object>Clipping Masks
    However, that will not necessarily cause the Transform palette's Height / Width fields to show you the dimensions you want if--as it sounds from your description--you have nested Clipping Paths.
    JET
