Daniel12378992
How to execute a function every certain period of time?
Apr 26, 2013 8:33 AM
Tags: #help #pro #3.0 #swf #action_script_3 #actionscript #flash_professional #actions #cs6 #flash_cs6
Hi guys!I have a very simple question.I have a budget and income variables.I want to make the player to recieve income every minute.But it's quite uncofortable to create a loop for every particular minute like if (minutes==1){} if (minutes==2){} and so on.How can make this loop occur every 60 seconds?
var fl_SecondsElapsed_3:Number = 1;
var minutes=2/fl_SecondsElapsed_3;
function fl_TimerHandler_3(event:TimerEvent):void
          trace("Прошло секунд: " + fl_SecondsElapsed_3);
          fl_SecondsElapsed_3++;
          if (fl_SecondsElapsed_3==60){
budget=budget+income;
    Apr 26, 2013 8:38 AM   in reply to Daniel12378992
    YOur function appears to be set up to work with a Timer class object, so all you seem to be mising is that Timer class object.  Create the Timer and set it to trigger every 60 seconds (60000 msecs)
    Apr 30, 2013 6:40 PM   in reply to Daniel12378992
    Yes, then you can eliminate the portion of that function that counts the 60 seconds
    May 3, 2013 6:52 PM   in reply to Daniel12378992
    The first argument in the Timer creation is the delay time, so the code would be more like....
    var fl_TimerInstance_3:Timer = new Timer(60000);
    The second argument is the number of times to repeat the timing.  If you do not specify it a number of times (or set it to 0), it will repeat indefitnitely.  To have it only trigger once you specify 1.
