Con.Form
how do i join multiple paths to make one object.....
Apr 26, 2013 9:33 AM
Tags: #illustrator
.... so as to be able to apply a fill over the whole object??
This might sound more obvious than it actually is in this case so i'll explain.  My partners artwork contains a lot of linework and unfortunately, i can't get the degree of accuracy i need with a continous path.  Therefore, the problem i have is joining lots of paths (some of which have endpoints joining midway through other paths) to make a single object with the strokes preserved, so i can apply a fill to the overall object or to individual sections.
I've tried unite, join and all the other commands that i'm aware of but all give undesired effects.  I've tried using a compund path but all that does is make them act as one but still doesn't do what i need with regards to filling the object.
A simplified example of what i need to achieve is this...... create a square using 4 seperate paths and then a cross through the middle using more seperate paths to create a 4 box square.  I need to be able to make this one object so i can fill each individual square a different colour if need be??
This is something i've found i will need to be able to do on a regular basis so any help is gratefully received
Thanks for any help in advance
    Apr 26, 2013 9:36 AM   in reply to Con.Form
    Check out Live Paint groups in the Help files.
    Apr 26, 2013 10:19 AM   in reply to Con.Form
    What tool did you use to create the paths?
    The Pen is what you want for long continuous paths.
    A square (Rectangle tool) with a cross through it (Line or Pen tool) is easy to colour if you make it into a Live Paint group.
    Following that you may (but don’t have to) expand the group as you wish.
