Dan Bryer
Print is 11 x 18 in LR4-Print module & much smaller in CS6 (same print). What is the problem?
Apr 26, 2013 11:21 AM
Tags: #photoshop_cs6_printer_problem
I use CS6 on a Mac pro os 10.8.3 & print to an Epson Pro 4900.
If I print an image via LR4 print module the print comes out at 12 X18 in. Recently I have tried that same image via CS6 and the print comes out  at 6 5/8 X 8 1/2 in.
In Print Settings in Printer Setup in the print module of CS6  stats "Super A3 / B 13 X 19 but the printed image dimensions are a little over half of that.
The printer used to print normally in CS6 print file.
  • Noel Carboni
    Dec 23, 2006
    Apr 26, 2013 11:29 AM   in reply to Dan Bryer
    What's the image size in Photoshop's Image - Image Size dialog?
    Does the image fill the page properly in the Photoshop print dialog preview area?
    Maybe it would be good for you to post a screenshot of what your'e seeing in the print dialog.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Apr 26, 2013 12:38 PM   in reply to Dan Bryer
    Use the little camera icon above the edit area.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Apr 26, 2013 4:49 PM   in reply to Dan Bryer
    Set the Scale value to 100%.   Consider also turning off that "Send 16-bit Data" checkbox, which I understand can be troublesome sometimes.
    -Noel
