RicardoEspositoCunha
Encore CS6 DVDs dont play in PC
Apr 26, 2013 1:32 PM
Tags: #encore #cs6 #dvd_burning
After install CS6 in my PC,
with same form,
comands, control B for botton,
DVDs dont play in PCs only in players
    Apr 26, 2013 1:35 PM   in reply to RicardoEspositoCunha
    What software player are you using?
    Apr 26, 2013 1:39 PM   in reply to RicardoEspositoCunha
    OK.
    What exactly happens when you try to play it?
    Apr 26, 2013 1:48 PM   in reply to RicardoEspositoCunha
    OK.
    And what exactly are you doing to try and make it play?
    Apr 26, 2013 4:24 PM   in reply to RicardoEspositoCunha
    I mean, once you put the disk into the drive, what exactly do you do next?  Take me through it, step by step.
    Apr 26, 2013 4:25 PM   in reply to RicardoEspositoCunha
    Alright.
    Have you tried opening the disk manually?
    Apr 27, 2013 4:14 AM   in reply to RicardoEspositoCunha
    Do you use Windows 8? I ask you because MS ripped off the mpeg2 codec wich exist in previous versions.
    Apr 28, 2013 7:00 PM   in reply to RicardoEspositoCunha
    Try using VLC.  It can handle DVD fine.
    Apr 28, 2013 7:03 PM   in reply to RicardoEspositoCunha
    In the DVD root I can see the archives as CDfiles and not as a DVD.
    This should have the VIDEO_TS folder, with the necessary IFO, BUP and VOB files.
    By "CDfiles," do you mean CDA, or something else? CDA is the format for Audio CD's.
    Apr 29, 2013 7:19 AM   in reply to RicardoEspositoCunha
    sounds like a problem of autoplay, which is a Windows setting, not related to any Adobe program.
    you do not say that you tried to play it manually. Real upgrade has to do with Real only. open windows media player and try to play the disc. as someone else said, VLC is great and will play just about anything. for autoplay issues do that in windows...
