TheirRNoavailableESC
import a javascript??
Apr 27, 2013 7:56 PM
Tags: #javascript
Hi I really need to know if its possible to import a .js to a new html page like you would a .css, if yes, HOW?
Could someone please help? I spent all day all this, I am ither really dumb or really blind.
    Apr 28, 2013 4:57 AM   in reply to TheirRNoavailableESC
    Put this in your code in the <head> section:
    <script type="text/javascript" src="put the location of the source file here"></script>
    Some people like to add language="javascript" too but it isn't an absolute necessity.
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Apr 28, 2013 8:13 AM   in reply to TheirRNoavailableESC
    @TheirRno....: CF solution will work. But depending on what type of .js file you're trying to incorporate, you could either load it within your <head> section or anywhere towards the very bottom of your page before closing </body> tag. The difference is pageload times. Javascript calls at the very bottom will load your actual webpage much faster. Again, this may not work at all times. If your webpage uses a certain function that is controlled using a .js file, that file may need to be loaded in <head> tag.
    But, if you're using a plug-in that you're trying to run only after your page completely finishes loading, these scripts can be at the very bottom.
    This is a generic structure of a HTML5 website with CSS, JS and jQuery library:
    <!doctype html>
    <head>
         <meta> <!--All metatags here-->
         <title>Title here</title>
         <link href="path/to/your/stylesheet.css" type="text/css"> <!--Your CSS files can be included here-->
         <script src="path/to/your/jquery/library.js" type="text/javascript"> <!--Your jQuery library can be included at the very beginning as all jQuery plugins you'll use will rely on the library-->
    </head>
    <body>
         YOUR MAIN WEBSITE CONTENT HERE
    <script src="path/to/your/plugin.js" type="text/javascript"> <!--Your plugins can be loaded here so the webpage loads faster-->
    </body>
    </html>
    And like CF says, the type definition is not necessary, but is definitely recommended to ensure browsers dont go into 'quirks' mode. Also to make your webpage W3 compliant.
    Apr 28, 2013 10:37 AM   in reply to TheirRNoavailableESC
    Oct 15, 2010
    Apr 28, 2013 9:04 PM   in reply to TheirRNoavailableESC
    Java & JavaScript are like apples and oranges. 2 completely different things. What you use normally for webpages with .js extension is JavaScript.
    when I made a responsive html and it keeps giving me errors when I try to add it
    What errors did you get?
