Imobach
Incomplete renders
Apr 27, 2013 7:42 PM
Hi all,
I'm trying to render some movies (between 30 and 60 secondos) in a batch (using aerender) and I'm getting some incomplete renders. I've got no errors in the After Effects log.
I'm using After Effects CS6 on Windows 7. My workstation have 24GB of RAM and I'm plenty of hard disk space.
Any idea?
    Apr 27, 2013 9:19 PM   in reply to Imobach
    Do you have your Output Render settings to complete comp or work area? Where you might have your work area shorter then your comp....
    *************PS While I have your attention....Do you have a minus, reduce, and x or close in the top RH corner of your screen to close AE or reduce / minus your screen? Mine is not there?
    Apr 27, 2013 9:41 PM   in reply to Imobach
    That's not much to go on. Do some of your comps have work areas that are shorter than the videos?
    Apr 27, 2013 11:00 PM   in reply to Imobach
    You will have to provide exact info about your render settings and comp settings. This could be a million reasons like having set a work area, framerate mismatches or even issues with your storage location...
    Mylenium
    Apr 28, 2013 10:00 AM   in reply to Imobach
    What does "almost" work mean? Do you get a full, working file? Your use of AE render is no doubt hacky, but that doesn't explain the problem. It's more likely some timeout problem with a certain footage I/O - source or render - or some effect lagging in processing and the render process shutting down...
    Mylenium
