EdwurdAdam
Linked correctly but, going to main menu instead of playing footage. Why?
Apr 28, 2013 11:55 AM
I am working in Encore CS 5.1
I have built a 9 menu Blu-Ray DVD with a 2 and a half hour wedding as the project.
I linked everything up and it should be ready to burn.
When I went to Preview it and make sure all the links work, most of them did.
A few of them would go back to the main menu for some reason.
Let me explain, I am testing out the links and mostly all worked fine. When I press some of them, they would play for about a second then go back to my main menu.
Why is this happening?
I linked up all the buttons to the chapters the right way.
Should I just go and burn the DVD as a test to see if it's working correctly or not?
If not, what should do?
Thanks in advance
Encore CS 5.1
    Apr 28, 2013 1:51 PM   in reply to EdwurdAdam
    Yes.
    then post a screenshot of your flowchart if it doesn't work correctly.
    Apr 28, 2013 5:08 PM   in reply to EdwurdAdam
    No such thing... it is either BluRay or DVD... the only way you can put BluRay on a DVD is for "about" 20 minutes, and then it will only play back in a BluRay player, not a DVD
    Make sure you have NO overrides set, and be very careful how you place your end actions
