TGbnn5
Will I be able to export a movie (consisting of several clips) well above 1gb with 2.5gb ram?
Apr 28, 2013 11:39 AM
  • joe bloe premiere
    Dec 6, 2009
    Apr 28, 2013 11:41 AM   in reply to TGbnn5
    Eventually...
    Apr 28, 2013 12:26 PM   in reply to joe bloe premiere
    Same answer that the caddy at The Old Course/St. Andrews gave his charge, when asked, "can I get there with a 5-iron?" "Eventually sir, eventually."
    Now, with a 64-bit OS, to run PrPro CS 5 - CS 6, are you saying that you only have 2.5GB of installed RAM?
    If so, I am surprised that a 64-bit OS will even run with that small amount of memory. Maybe I am just misunderstanding something there?
    Apr 28, 2013 5:36 PM   in reply to TGbnn5
    This message has a really good graphic about requirements - http://forums.adobe.com/thread/810750
    Since you do not describe what you are editing (click the link I just posted) I will make some general comments
    Core 2 is going to be VERY slow with any kind of HiDef file
    4Gig Ram is VERY low, barely enough to run Win7 and PPro, with almost no memory left to do any actual work
    -8Gig is the practical minimum, 16Gig is better
    You do not mention hard drives... you need at least two... 1st for Win7 and all software, 2nd for projects and video files
    -separate drives, never a partition http://forums.adobe.com/thread/650708 for more on partitions
    Apr 28, 2013 5:44 PM   in reply to TGbnn5
    Thank you for that clarification. I must have mis-read the installed RAM.
    I would look at John T's links.
    Apr 29, 2013 8:06 AM   in reply to TGbnn5
    External eSata or USB3 are both fast enough for video editing... eSata is better - http://forums.adobe.com/thread/1117813
    Apr 29, 2013 11:37 AM   in reply to TGbnn5
    >Nice, but can this combat the ram issue as well? Would be optimal if I can get all covered in one external device.
    Huh? Ram and external drive are completely different things... you need more ram (what I said in #4) so your software will work better... you need at least 2 drives so your files load and edit better
