Lyndonhr
Opening multiple pictures in Photoshop
Apr 28, 2013 3:07 PM
I am working on a picture file, jpegs, changing the size, the level, etc. I open several pictures usually
3 or 4 and when I try to open the next I receive a pop up error message that says: "Could not
complete your request because of a program error.” This has just started to happen recently,
probably since I upgraded to CS6. Previously I could work on a file and have 100 or so pictures
open and still be able to open additional pictures. I have downloaded and in installed all available
updates and the message I receive when I check for updates is: “Your applications are up-to-date
as checked less than a minute ago.” I tried to Edit>Purge>All, Reset Preferences, Deleted the
Adobe Photoshop Ver. 6 Prefs.psp folder and pressed Ctrl+Alt+Shift on Photoshop startup and
deleted Adobe Photoshop Settings file. Did not work, what next?
    Apr 29, 2013 1:51 AM   in reply to Lyndonhr
    Update your graphics driver or turn off OpenCL/ OpenGL in the prefs. Pretty obviously you are running out of graphics card VRAM because your buffers fail to flush, which is a driver problem...
    Mylenium
    Apr 29, 2013 7:49 AM   in reply to Lyndonhr
    This will be found in edit/preferences/performance/ under Use Graphics Processor.  Try unchecking it as this takes GPU out of circuit.  If no changes probably not GPU.  Then try Basic mode in advanced settings.
    Apr 29, 2013 5:29 PM   in reply to Lyndonhr
    This means you gpu driver is not working correctly.  It will work this way but you will be missing some features that the GPU provides.
    All you can do is check the OS updates.
    Apr 29, 2013 6:07 PM   in reply to Lyndonhr
    My mistake, thought you were a similar problem on Mac where the drivers are part of OS.  You need to make sure you have latest GPU driver.
    Apr 29, 2013 7:08 PM   in reply to Lyndonhr
    Do you only have the one GPU?  PS does not like 2, especially of different models.  Check to make sure you do not have an onboard Intel also.
