Kariko1337
XML Data in LinkBar
Apr 29, 2013 6:52 AM
Tags: #flex #xml #linkbar #flex3
Hi guys,
I'm new to FLEX and still learning a lot, but am struggling with the following issue,
I have a simple "Book List" style application that i have created. It is linked to an XML document and i am able to edit/delete/add items in the XML document.
Now what i want to do is have a LinkBar at the top with three buttons for different stypes of lists (different XML documents)
I have tried to take my working application and put it into a LinkBar but it fails to work.
Any help would be awesome.
Cheers
Kariko
<mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" initialize="{init()}"
                                                            layout="absolute" height="451" width="542">
                              <mx:Script>
                              <![CDATA[
                                        import mx.collections.XMLListCollection;
                                        // Code block 1
                                        private var myXml:XML;
                                        private var myLoader:URLLoader;
                                        [Bindable]
                                        private var myBooksCol:XMLListCollection;
                                        // Code Block 2 //
                                        public function init():void
                                                  var dataFile:File = new File('app-storage:/data.xml');
                                                  if(dataFile.exists){
                                                            var myReq:URLRequest = new URLRequest('app-storage:/data.xml');
                                                            myLoader = new URLLoader()
                                                            myLoader.addEventListener(Event.COMPLET E, dataComplete);
                                                            myLoader.load(myReq);
                                                  }else{
                                                            createFile()
                                        // Code Block 3 //
                                        private function createFile():void
                                                  var xmlToSave:XML = new XML('<flashEnabled><books>' +
                                                            '<book>' +
                                                            '<title>Contact1</title>' +
                                                            '<series></series>' +
                                                            '<author></author>'+
                                                            '<ISBN></ISBN>' +
                                                            '</book>' +
                                                            '</books>' +
                                                            '</flashEnabled>')
                                                  var saveStr:String = xmlToSave.toXMLString();
                                                  var file:File = new File('app-storage:/data.xml');
                                                  var fs:FileStream = new FileStream();
                                                  fs.open(file, FileMode.WRITE);
                                                  fs.writeUTFBytes(saveStr);
                                                  fs.close();
                                                  init();
                                        //Code block 4
                                        private function dataComplete(e:Event):void
                                                  myXml = new XML(myLoader.data.toString());
                                                  myBooksCol = new XMLListCollection(myXml..contact);
                                        //Code Block 5
                                        private function updateList():void
                                                  myBooksCol = new XMLListCollection(myXml..contact.(name.toLowerCase().indexOf(search_t xt.text.toLowerCase()) != -1 ))
                                        //Code Block 6
                                        private function saveData(e:Event):void
                                                  var xmlToSave:XML = new XML('<flashEnabled><books>'+myBooksCol.toXMLString()+'</books></flash Enabled>')
                                                  fs.close();
                                        //Code Block 7
                                        private function addItem():void
                                                  myBooksCol.addItem(new XML('<book>' +
                                                            '<author></author>' +
                                                            '<ISBN></ISBN>' +
                                                            '</book>'))
                                        private function removeItem():void
                                                  myBooksCol.removeItemAt(myDg.selectedIndex);
                    </mx:Script>
                              <!-- Code Block 8 -->
                              <mx:DataGrid bottom="60" top="10" left="10" id="myDg" dataProvider="{myBooksCol}" editable="true" right="10">
                              <mx:columns>
                                        <mx:DataGridColumn headerText="Title" dataField="title"/>
                                        <mx:DataGridColumn headerText="Series" dataField="series"/>
                                        <mx:DataGridColumn headerText="Author" dataField="author"/>
                                        <mx:DataGridColumn headerText="ISBN" dataField="ISBN"/>
                              </mx:columns>
                    </mx:DataGrid>
                              <mx:Label x="10" text="Search:" bottom="10"/>
                              <mx:TextInput x="65" id="search_txt" bottom="10"/>
                              <!-- Code block 9 -->
                              <mx:Button x="233" label="Go!" id="go_btn" click="{updateList()}" bottom="10"/>
                              <mx:Button label="Save" click="{saveData(event)}" id="saveButton" bottom="10" right="10"/>
                              <mx:Button x="307" label="Add" click="{addItem()}" bottom="10"/>
                              <mx:Button x="381" label="Remove" click="{removeItem()}" bottom="10"/>
</mx:WindowedApplication>
