Teodolinda234
Photoshop CS4 crashes on Mac OS X 10.8.3
Apr 29, 2013 8:57 AM
Tags: #crash #photoshop_cs4 #photoshop_cs4_mac #mac_osx_10.8.3
I have CS4 on my mac OS X 10.8.3. Photoshop CS4 is crashing all the time.
I update it regularly.
It used to crash using layers, so i changed the  graphic settings as suggested in this forum, now this is ok.
Now PS crashes:
- everytime i do "save for web"
- often when i work on text layers
- sometimes for nothing in particular
It is really impossible to work in this conditions.
Fireworks CS4 crashes too when trying to save a file. For no special reason.
Please help me.
Thank you,
    Apr 29, 2013 9:12 AM   in reply to Teodolinda234
    Hardware specs?
    Please read this FAQ for advice on how to ask your questions correctly for quicker and better answers:
    http://forums.adobe.com/thread/419981?tstart=0
    Thanks!
    Apr 29, 2013 10:43 AM   in reply to Teodolinda234
    Without the crash report, we can only guess at what might be causing it.
    Apr 30, 2013 12:04 PM   in reply to Teodolinda234
    We need the whole thing. Different parts can be important depending on the actual cause.
    Apr 30, 2013 1:45 PM   in reply to Teodolinda234
    That's not a crash report.  That appears to be a time sample of Photoshop while you were using SaveForWeb and the OS was waiting for your disk.
    If that was caused by a freeze/hang -- then you have something wrong with your disk.
    If you took that sample at some other time: why?
    And please understand that crashes and hangs/freezes are very, very different beasts.
    May 2, 2013 11:21 AM   in reply to Teodolinda234
    First, make sure you have a backup of your data.
    Then try using Disk Utility to repair the disk (and check the SMART status - I had a disk silently fail recently, but the SMART status told me that it was failing).
    Disable any file system utilities you may have running (anti-virus can cause problems if it has a bug).
    And worst case, replace it with a new hard disk.
