I had a battle with this, I've googled and seen more than 100 results and have not found the solution.
I installed many times "Coldfusion", in different ways, in different distributions of linux and can not find the solution to the much hated "flex2gateway", tryig so many fixes but none worked for me, I keep getting the 404.
System details: Debian Wheezy (7.0), Coldfusion 10, Apache 2.2.22
I hope someone can help me.
Solved.
Adding this lines on /etc/apache2/mod_jk.conf :
# Fix para Flex2gateway
<IfModule jk_module>
JkMount /*.cfm ajp13
JkMount /*.cfc ajp13
JkMount /*.do ajp13
JkMount /*.jsp ajp13
JkMount /*.cfchart ajp13
JkMount /*.cfres ajp13
JkMount /*.cfm/* ajp13
JkMount /*.cfml/* ajp13
JkMountCopy all
</IfModule>
Solved.
JkMount /*.do ajp13
JkMountCopy all
</IfModule>
Good Morning,
My name is Jose Valera Corferias Jobs in Bogota Colombia, we used Coldfusion 10 with RedHat 6.2, in our case Apache httpd folder not currently have the same drawback flex2gateway but the location that you provided does not exist, my question is: Does the process is the same regardless of the version of Linux used or depends on the version of Linux?.
I appreciate the attention given
Hi Jose, I used this solution on Mac OS X with MAMP PRO and works, you need to find the "mod_jk.conf" file on conf folder of apache.
Thanks worked perfectly.
