dmiddletonla
Cant get my ad banner into a clickable link
Apr 29, 2013 7:49 PM
Hi all - hoping someone can help me.
I have created a simple ad banner in Flash CS5. I am trying to make it so that when I u/l the .swf to my site, the banner will be a clickable link that will take me to the desired place. I have found some tutorials on yt - one in particular was very good. I followed it to the tee, but it still does not work. The banner exports just fine, but there is no URL associated with it. I am using AS 3.0 and this is the code I have:
import flash.events.MouseEvent;
import flash.net.URLRequest;
circle.addEventListener(MouseEvent.CLICK,pressed);
function pressed(e:MouseEvent):void
 var url:String = "[http://www.umysite.com | http://www.umysite.com]"
 var request:URLRequest = new URLRequest(url);
 navigateToURL(request,'_blank');
Can someone please tell me what I am missing here? Thank you!
  • kglad
    Jul 21, 2002
    Apr 29, 2013 10:08 PM   in reply to dmiddletonla
    that url string is not a url.  use something like:
    var url:String = "http://www.umysite.com"
  • kglad
    Jul 21, 2002
    Apr 30, 2013 10:01 AM   in reply to dmiddletonla
    then that will work if circle is pressed, you have no popup blocker, no security sandbox issue and you use a valid url.
  • kglad
    Jul 21, 2002
    Apr 30, 2013 11:32 AM   in reply to dmiddletonla
    what's the link you're using to test your banner?
  • kglad
    Jul 21, 2002
    Apr 30, 2013 1:34 PM   in reply to dmiddletonla
    using as2 won't make any difference.
    can you confirm circle is dispatching the click event and pressed() is being called?
  • kglad
    Jul 21, 2002
    Apr 30, 2013 4:24 PM   in reply to dmiddletonla
    you probably have a sandbox security issue.  test on a (non-local) server.
  • kglad
    Jul 21, 2002
    May 2, 2013 9:22 AM   in reply to dmiddletonla
    make sure whatever object has your click listener exists throught the main timeline.
    if there's more than 1 keyframe in the layer that contains that object, you may be replacing that object and not realize it because of the way your fla was created.
    so, make sure there's only 1 keyframe (likely frame 1) in the layer that contains the object with your click listener.
    kg
