Combining all clips
Apr 29, 2013 9:19 PM
I'm working on a project that has 25 video tracks of things all stacked on top of each other.  I've got everything the way I want it and I want to know if there is a shortcut to moving all the tracks down and combining them so there is only one video track of all the things that were on the top, the highest level, the ones that were displayed in the preview.  Without having to manually drag each and every one downward and overlap them.
    Apr 29, 2013 9:51 PM   in reply to owiseone61755
    You can make a Nest of them.That would be all layers into a single layer.
  • joe bloe premiere
    Dec 6, 2009
    Apr 30, 2013 6:57 AM   in reply to owiseone61755
    I would post a link about nesting sequences,
    but you obviously don't read the links I provide for you.
    So....
    Frankly, there is no reason for you to have 25 video tracks
    aside from a basic misunderstanding of editing in Premiere.
    http://forums.adobe.com/message/5268755#5268755
  • joe bloe premiere
    Dec 6, 2009
    Apr 30, 2013 8:08 AM   in reply to owiseone61755
    Premiere Pro CS5-CS6 Reference
    (.pdf 12 MB download)
    http://helpx.adobe.com/pdf/premiere_pro_reference.pdf
    Adobe Premiere Pro Help and tutorials
    http://helpx.adobe.com/premiere-pro/topics.html
    Getting Started with Premiere Pro CS6
    http://www.video2brain.com/en/getting-started-with-premiere-pro
    FAQ: How do I learn Premiere Pro?
    http://forums.adobe.com/thread/878529?tstart=0
  • joe bloe premiere
    Dec 6, 2009
    Apr 30, 2013 11:45 AM   in reply to owiseone61755
    Well, I'll say this...
    For a first editing project, and having no idea
    what you're doing, your video is pretty entertaining.
    And, I was glad to see Alex & his Droogs made the cut.
    Just imagine what you can do with a little bit of learning.
    Good luck, and read.
  • joe bloe premiere
    Dec 6, 2009
    Apr 30, 2013 3:40 PM   in reply to owiseone61755
    This is the result of stacking 25 video tracks.
    Go into your Nested Sequence at the point
    where you can see video 'bleeding in' at the edges.
    Scroll down through all of your tracks and eliminate the
    offending track(s) that are intruding into your top track.
    You can use the Ctrl+K shortcut you learned
    to snip out the bits you don't need.
    In the real world, your edit should only use 2-3 tracks at most,
    and most folks would probably do it in one!
    You will look back at this and chuckle once you are more familiar w/Pr.
  • joe bloe premiere
    Dec 6, 2009
    May 1, 2013 11:28 AM   in reply to owiseone61755
    Is it safe for me to delete all of the temporary files associated with the project?
    Yep.
    If you need to re-visit your project, Premiere will re-generate them.
