Blissfulspace
Post Paypal buttons in to Dreamweaver CS6
Apr 30, 2013 1:49 AM
Hi
I've created a add to cart button in Paypal, however when I paste the code from Paypal into Dreamweaver it does not work, I end up with yellow code warning notification, but not sure how to correct the problem.
Can anyone advise what I should do.
Martin
    Apr 30, 2013 3:25 AM   in reply to Blissfulspace
    You can see the code and cannot figure out the problem. How do you expect us to find the problem blindfolded.
    This is unfair! Please post a link to your site so that we can be on equal footing.
    Apr 30, 2013 9:00 AM   in reply to Blissfulspace
    You have used target="" twice in the form. I'm not even sure what that is to be honest. I would remove both instances:
    <form action="https://www.paypal.com/cgi-bin/webscr" method="post">
    Apr 30, 2013 10:56 AM   in reply to Blissfulspace
    Change your code to below and it will process properly and validate too
    <form target="paypal" action="https://www.paypal.com/cgi-bin/webscr" method="post">
    <input type="hidden" name="cmd" value="_s-xclick">
    <input type="hidden" name="hosted_button_id" value="QUFELQSUGRXGJ">
    <input type="image" src="https://www.paypalobjects.com/en_GB/i/btn/btn_cart_LG.gif" name="submit" alt="PayPal – The safer, easier way to pay online.">
    <img alt="" src="https://www.paypalobjects.com/en_GB/i/scr/pixel.gif" width="1" height="1">
    </form>
    If you will have a bunch of buttons to place, may I suggest you save the code as a "DW Snippet"
    Before saving, just replace the hosted button value with XXX and when you need a new  button, just select the smippet and click insert.  Then all you need to do is replace the XXX with the appropriate hosted value, and voila, a functioning button that will validate.
