jmacphot1975
Javascript rollover image vallidation issue
Apr 30, 2013 5:24 AM
Tags: #image #javascript #cs6
Hi....again!
I am trying to add rollover images using CS6 however the code it places on my page won't vallidate and gives a heap of errors.
Can someone advise me how to attach the code to a seperate sheet so that my index page vallidates? or is there a way to hide the script so that the vallidation can't see it?
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<meta name="description" content="Photography portfolio using both Nikon d3200 and canon ixus 65" />
<meta name="keywords" content="Portfolio,Pictures,Camera,Lenses,Photography,photo,informati ve,functional,evolving,expanding,pics,new,photographer,hobby,John,MacK innon,images,eye,catching,colourful,black,white
<meta name="author" content="john mackinnon" />
<meta name="robots" content="index, follow" />
<meta name="revisit-after" content="3 month" />
<title>JMACPHOT.com Landing Page</title>
<!-- Photography, portfolio, personal -->
<link rel="shortcut icon" href="images/favicon.ico" />
<link href="css/layout.css" rel="stylesheet" type="text/css" />
function MM_swapImgRestore() { //v3.0
  var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_preloadImages() { //v3.0
  var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
    var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
    if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_findObj(n, d) { //v4.01
  var p,i,x;  if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
    d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
  if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
  for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
  if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
  var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
   if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
</head>
<body bgcolor="#000000" onload="MM_preloadImages('images/on.png','images/ps_on.png')">
<div align="center">
  <p><img src="images/landing.jpg" alt="landing" width="800" height="400" usemap="#Map" border="0" />
    <map name="Map" id="Map">
      <area shape="rect" coords="284,251,477,289" href="home.html" alt="#" />
    </map>
  </p>
  <p><a href="#" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('flash','','images/on.png',1)"><img src="images/off.png" width="190" height="100" id="flash" /></a><a href="#" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('photoshop','','images/ps_on.png',1)"><img src="images/ps_off.png" width="190" height="100" id="photoshop" /></a></p>
</div>
</body>
</html>
Cheers
John
    Apr 30, 2013 6:06 AM   in reply to jmacphot1975
    I am not sure what 'flash' and 'photoshop' have in common with rollover images.
    May I suggest that you use jQuery to solve your problem.
    To do this, you need to link the library to your document as in
    <script src="//ajax.googleapis.com/ajax/libs/jquery/1.9.1/jquery.min.js" ></script>
    The markup will look like
    <img src='/folder/image1.jpg' id='imageid'/>
    and the JS like
    <script>
    $('#imageid').hover(function() {
    (this).attr('src', '/folder/image2.jpg');
    }, function() {
    (this).attr('src', '/folder/image1.jpg');
    </script>
    Apr 30, 2013 6:12 AM   in reply to jmacphot1975
    DW's javascript will do that from time to time.
    I typically move it to an external .js file when that happens so I can get the rest of the page to validate.
    EDIT: To move it out, copy and paste everything from between the <script> tags in the <head> into a new .js file. Then link to that file from the <head> like so...
    <script type="text/javascript" src="your_javascript.js"></script>
    Do not include the <script> tags in the actual .js file
