Exported video shorter than Work Area length?
Apr 30, 2013 2:14 PM
Tags: #off #video #pro #premiere #export #cut #short #shorter
I exported an MPEG2-DVD using the NTSC High Quality Progressive Preset and it came out about 8.5 minutes shorter than the actual Work Area of the sequence.  The video should be 68 minutes long, but instead the video is only 59 minutes and 11 seconds long.  As far as I can tell, The beginning and the end look the same.  Funny thing is, the .wav file that Premiere produces is the correct length (68 minutes), yet the .m2v file is 8.5 minutes shorter.  My source footage is AVCHD, 1080p filmed at PF30 in a 60i container (which should be edited in a AVCHD 1080p30) sequence.
    Apr 30, 2013 2:28 PM   in reply to derekl123
    Copy all clips and put them in a 1080p timeline.
    Make sure Premiere interprete them as prograssive.
    Export from Premiere.
    If there are any gaps in the video tracks fill them with black video.
    Make sure the videotrack has the same length as the audio track.
    See if that will help
    Apr 30, 2013 9:30 PM   in reply to derekl123
    Bring the files into Encore and check them.  Don't trust what Windows Explorer says about them.
    Apr 30, 2013 9:55 PM   in reply to derekl123
    You're welcome.
