bluenun77
install CS5 extended on Imac
Apr 30, 2013 6:11 PM
how do I install CS5 extended on my new iMac?  I have read to download trial version then add in serial number - but I cannot find a trial version of CS5 extended.
  • kglad
    Jul 21, 2002
    Apr 30, 2013 6:23 PM   in reply to bluenun77
    these are the only cs5 programs available via adobe or its affiliate prodesigntool.com
    if you follow all 7 steps you can dl a trial here:  http://prodesigntools.com/all-adobe-cs5-direct-download-links.html
    and activate with your serial.
    if you have a problem dl'g, you didn't follow all 7 steps.
    May 1, 2013 4:35 AM   in reply to bluenun77
    If you're looking for Photoshop CS5 Extended then that's the download you'll receive from the download link at http://prodesigntools.com/all-adobe-cs5-direct-download-links.html
    May 1, 2013 11:36 AM   in reply to bluenun77
    Bluenun77 there is only one Photoshop installer.  Depending on your serial number, and if you meet or exceed the needed system requirements, will depend if Photoshop CS5 Extended will work or not.
    You are correct though there are other options such as sharing your optical drive over the network to allow you to install.  You may want to consider transferring your installation files from the DVD to a USB drive for future installations.
