PaoloJerome
Problem with Rounded Rectangle Tool
Apr 30, 2013 7:55 PM
Tags: #illustrator #tool #rectangle #rounded
I want to change the radius using (Right Arrow) but now it's only letting me choose to 1 radius and nothing in between.
    May 1, 2013 12:22 AM   in reply to PaoloJerome
    You need to provide system info, version info and other details. AI not responding to certain keyboard inputs could be a system problem, after all...
    Mylenium
    May 1, 2013 12:33 AM   in reply to PaoloJerome
    What are the dimensions of the rectangle? Is it possibly so small that only one increment is feasible?
    If the width and/or height of the rectangle is equal to or smaller than the Preferences > Corner Radius setting, there is only one step.
    May 1, 2013 2:08 AM   in reply to PaoloJerome
    PaoloJerome,
    You may untick Align to Pixel Grid if ticked (in the Transform panel where you should also untick it for new paths), and consider the setting for your use of that kind of document).
    May 1, 2013 2:19 AM   in reply to Jacob Bugge
    Are you using a Wacom tablet? There's an issue with Wacom drivers which cause the corners to RAPIDLY change which at times may appear like one step unless you very quickly TAP the arrow key.
    This was fixed for a version or two, then crept back in.
    May 1, 2013 2:33 AM   in reply to PaoloJerome
    I don't understand those last two posts, Paolo. Does that mean you do indeed use a Wacom? If so, it's up to Wacom to fix it and I would not hold my breath. It's been an issue for litterally a decade or more.
