khauscreative
Indesign, repeat image to create pattern
Apr 30, 2013 7:25 PM
Is there a way to tile an image in Indesign, like you can in Photoshop/patterns to Illustrator/patterns? I don't want to create an image, I want to import an image and how it repeat.
Why? To keep file sizes down and to speed up work.
    Apr 30, 2013 8:08 PM   in reply to khauscreative
    Illustrator is the place to do patterns. The new Pattern creation feature in Illustrator CS6 is totally easy and intuitive.
    InDesign has nothing similar natively. There is a pattern maker plug-in from Teacup Software:
    PatternMaker - Powerful PostScript patterns ... - Teacup Software.
    May 1, 2013 5:19 AM   in reply to khauscreative
    You can use step and repeat to create a grid of images....    It won't reduce the file size, though. Each instance will be a link (presuming you placed the original rather than pasting it), so you'll have a few bytes in pointer info for each one, but it isn't going to bloat the file any more than placing many different links. If it's a problem, make your pattern externally and link to that as a single image. In anay case, I don't think it will have any effect at all on the size of a PDF that you would export.
    May 1, 2013 12:12 PM   in reply to khauscreative
    As it happens, Kelly Vaughn (also known as Her Royal Geekness) posted a blog post on Patterns In InDesign just the other day: http://documentgeek.blogspot.nl/2013/04/ignite-2013-making-patterns-in -indesign.html
    While it may not be exactly what you are looking for, it does give you a good overview of what *is* possible using InDesign.
