• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Adobe Connect SCCM
New Here ,
Apr 30, 2013 Apr 30, 2013
How can I deploy this out to all users so that they can share there screen?
Views
6.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
May 01, 2013 May 01, 2013
Connect is a server based product, so other than having Flash Player 10.3 or newer on the computers you manage you shouldn't need to push anything. If the users need to share their screen they will need the add-in, but they will be prompted to install it when needed, and once it is installed, they shouldn't need to re-install it. If you need the installer files for the Add-in, you can find them on the Getting Started page for your server, or you can find them here: http://www.adobe.com/support/connect/downloads-updates.html#meeting-add-ins
Votes
Translate
Translate
Report
Report
New Here ,
I wish to push out the plug in for screen sharing with SCCM as the users do not have rights to install it. The problem is that if I install the plug in on a machine it is tied to the user profile not the machine and that is why adobe made the adobe connect add in checker but that does not work eaither.
Votes
Translate
Translate
Report
Report
LEGEND ,
May 02, 2013 May 02, 2013
I recall that this has been attempted in the past, though I'm not sure to what level of success... Here are a few threads that addressed this deployment need.
http://www.connectusers.com/forums/topic/4541/installing-the-connect-addin-using-windows-installerms...
http://www.connectusers.com/forums/topic/1404/connect-addin-per-user-or-per-computer/
They are older threads, but they all come to the same conclusion, that it cannot be easily done. There may be a solution or tow in these threads though.
It may also be worth reaching out to support to see if they have put a solution together since 2010.
Votes
Translate
Translate
Report
Report
New Here ,
May 05, 2013 May 05, 2013
Thanks I will dig through and see if it suites.
I think that I will also move everyone to Lync and cut back our licences for Adobe Connect. This is just plain stupid way to manage software and I will avoid it where possible.
Thanks again.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
May 09, 2013 May 09, 2013
I would recommend contacting support on this as well. We do support large-scale deployments of the Add-in using Citrix's XenApp solution and a tool called the Adobe Connect "Add-in Checker" which is available with all on-premise (non Adobe hosted) deployments.
Here were the steps to accomplish this with XenApp for Connect 8, the steps should be the same for 9:
http://helpx.adobe.com/adobe-connect/kb/support-citrix-xenapp-connect-8.html
AFAIK, customers have used the Add-in Checker to deploy en-masse over different environments, but I haven't helped anyone in that situation directly, only XenApp users.
Incidentally, without the add-in checker and just focusing on the Add-in executable...you can use flags like /SP-, /SILENT, /VERYSILENT, /SUPPRESSMSGBOXES to eliminate user prompts when installing the add-in, eg. "setup.exe /VERYSILENT".
Hope this helps!
Votes
Translate
Translate
Report
Report
New Here ,
May 28, 2020 May 28, 2020
LATEST
Please advise on how i can uninstall Adobe Connect
It was installed using AdobeConnectAddinInstaller.exe on SCCM
Votes
Translate
Translate
Report
Report
New Here ,
Apr 26, 2017 Apr 26, 2017
Perhaps this is a new twist on things since OP made his OP, but Adobe Connect installs to the user's AppData folder and thus is installable by non-admin users.  I just tested it with a limited user and the install went without a hitch.  Only caveat is that I don't have any actual content with which to do a full-blown test.  My 'success' has only been confirmed by the Adobe Connect test page.
Votes
Translate
Translate
Report
Report
Explorer ,
Aug 02, 2017 Aug 02, 2017
+1 for the user installing the addin himself, but I found out right after completing the sccm application, and some of them may be concerned by the warning in chrome (and it won't appear in the add remove program if installed this way)
The install part is not hard but the detection was.
here my command line
AdobeConnectAddinInstaller.exe /silent /log=%windir%\temp\AdobeConnectAddin979.366.log /NOCANCEL /CloseApplications /NORESTART
here is the powershell script I'm using as the "detection method" to check if it is correctly installed (you won't need that if you create a package instead of an application)
hopefully it can be usefull for someone else.
# CHECK IF FILE EXIST IN CURRENT USER APPDATA, IF YES CHECK IF VERSION IS GREATER OR EQUAL TO THE SPECIFIED VERSION
# IF YES RETURNS TRUE
# OTHERWISE RETURNS FALSE = APPLICATION IS NOT INSTALLED.
#USED IN SCCM APPLICATION DETECTION RULE
## https://social.technet.microsoft.com/Forums/en-US/3fd796c4-45f0-42cf-bc3d-bccd6caf73a8/det ection-method-using-userprofile-in-the-path?forum=configmanagerapps
##https://rohnspowershellblog.wordpress.com/2013/12/16/getting-accurate-file-versions/
###That method requires version 3.0. If you have 2.0, you should be able to get it to work,
$path = "$env:APPDATA\Macromedia\Flash Player\www.macromedia.com\bin\adobeconnectaddin\adobeconnectaddin.exe"
$path
IF(Test-Path $path) {
# FILE EXIST, CHECK VERSION
$VersionInfo = (Get-Item $path).VersionInfo
$VersionInfo
$FileVersion = ("{0}.{1}.{2}.{3}" -f $VersionInfo.FileMajorPart,$VersionInfo.FileMinorPart, $VersionInfo.FileBuildPart, $VersionInfo.FilePrivatePart)
$FileVersion
([version] $FileVersion -gE [version] "11.9.979.366")
ELSE {$false}
Votes
Translate
Translate
Report
Report
New Here ,
Jan 31, 2018 Jan 31, 2018
I was able to execute the installation properly for each using using Bigfix, but you could also do it via group policy.  You need to be able to detect the current logged in user, or use variables which return or bypass the need for related information such as user key and user name.
I've cleaned this up SLIGHTLY to remove some of the more obvious Bigfix-specific code, but be sure you also check for and clean up anything in curly braces { } and any ifs.  That means it's relevance within the action: it's resolving that information to decide the correct solution for each deployment.
//Kill adobeconnectaddin.exe if the program is running for upgrade to run
taskkill /F /IM adobeconnectaddin.exe
// only continue if there is exactly 1 user logged on since this is a profile specific install
// IBM Bigfix script here - you should adapt or skip this section.
continue if {(exists current user) AND (1 = number of logged on users)}
// uninstall older versions
//// if for detection of older versions
if {exists (files "adobeconnectaddin.exe" whose(version of it <= "11.9.980.387") of folders "AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\adobeconnectaddin" of folders (name of current user) of folders "C:\Users")}
//// execution of uninstall with relevance for current user - swap relevance/variable, depending upon your deployment platform
cmd.exe /c "C:\Users\{name of current user}\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\adobeconnectaddin\unins000.exe" /VerySilent
endif
// if related to flash player, I can't remember why but we needed it
if {exists folder "C:\Users\{name of current user}}\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\adobeconnectaddin"}
cmd.exe /c rmdir /q /s "C:\Users\{name of current user}\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\adobeconnectaddin"
endif
// execution of install with relevance (or insert your variable) for user directory.  You can point the installation to the specific user folder!!!  But it doesn't add uninstallation registry keys, so it doesn't show up in A/RP...yet!
AdobeConnectAddinInstaller.exe /VERYSILENT /DIR="C:\Users\{name of current user}\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\adobeconnectaddin"
// Add Uninstall registry entries manually.  This section is in bigfix action script - you could probably convert this to reg add or whatever your platform is pretty quickly, or simply deploy a reg file already containing them!  Just be sure you add it to the HKCU, or the specific user registry hive you're trying to install to.
// begin create file
delete __createfile
createfile until END
echo Windows Registry Editor Version 5.00 >> adobeconnect.reg
[{user key of logged on user}\Software\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Connect 9 Add-in]
"DisplayName"="Adobe Connect 9 Add-in"
"Publisher"="Adobe Systems Incorporated"
"DisplayVersion"="11.9.980.387"
"DisplayIcon"="C:\\Users\\{name of current user}\\AppData\\Roaming\\Macromedia\\Flash Player\\www.macromedia.com\\bin\\adobeconnectaddin\\adobeconnectaddin.exe,0"
"InstallDate"="{(year of current date as string) & (month of current date as two digits as string) & (day_of_month of current date as two digits as string)}"
"NoRepair"=dword:00000001
"NoModify"=dword:00000001
"HelpLink"="http://helpx.adobe.com/adobe-connect.html"
"UninstallString"="C:\\Users\\{name of current user}\\AppData\\Roaming\\Macromedia\\Flash Player\\www.macromedia.com\\bin\\adobeconnectaddin\\unins000.exe"
END
delete AdobeConnect.reg
move __createfile AdobeConnect.reg
// execute add registry keys
regedit /s AdobeConnect.reg
// cleanup of older versions
if {exist key "Software\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Connect Add-In" of (user key of logged on user) of native registry}
delete __createfile
[-{user key of logged on user}\Software\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Connect Add-In]
END
delete legacyremoval.reg
move __createfile legacyremoval.reg
regedit /s legacyremoval.reg
Votes
Translate
Translate
Report
Report
