Program Monitor stops showing video playback
Apr 30, 2013 8:22 PM
Tags: #freezes #source_monitor #program_monitor #playback_head
Hello,
   I lose composite video playback picture in the Program monitor and Source monitor after a few minutes. Audio still plays.
While the clip is playing, a bar of random video colors from the clip forms near the entire top 10 rows of pixels from left edge to the right edge, then the clip freezes video, but audio can still be heard. After a while, an error message pops up and Premiere has to be forced closed. 'NVIDIA OpenGL driver detected a problem with the display driver and is unable to continue. Error code: 3'
It happens on all projects ranging of different resolutions and sizs from 30 seconds to 40min. I suspect it has something to do with that error of the video and display drivers not communicating, but something from Premiere causes that to happen after the clip has been playing a while. I have tried some online solutions others have had success with, but there has not been a lot of fully documented solutions for Windows users.
This has put all of my projects on hold. Any ideas on how to resolve this?
Other clues:
able to see playback via other display modes like vectorscope or rc waveform
able to see video frames change if manually moving the blue playhead
Windows Media Player plays the video files fine
Close Premiere , reopen Premiere plays fine for a few minutes
APPLICATION SETTINGS-
Adobe Premiere Pro CS 5.5 (5.5.2)
Scratch Disks: using separate SATA HDD
player settings: default player - adobe player
playback settings -
Aspect Ratio Conversion : Software
playback and paused resolution: 1/2
display first field
Example project settings-
sequence settings: AVCHD 1080i square pixel, 1920x1080 16:9 30fps Drop-Frame
video previews: I-Frame Only MPEG
Codec: MPEG I-Frame
Frame Rate: 29.97
SYSTEM DETAILS-
OS: Windows 7 Pro 64bit
RAM: 12.0 GB
RAM memory in use (task manager): 3.8gb / 12GB
Desktop Theme: Windows Classic (aero turned off)
Intel Core i7 920 2.67GHz
NVidia Quadro FX 3800 driver, 1GB GDDR3,  driver: 9.18.13.697
3D disabled, hardware processing disabled, allow software to maintain color settings, 60hz
Display: Asus VG278 1920 x 1080 native, using 60hz
Display Driver: Generic PnP Monitor (there is no real driver for this monitor from the MFG)
Motherboard BIOS: No onboard graphics chip
  • joe bloe premiere
    Dec 6, 2009
    May 1, 2013 3:53 PM   in reply to napynap
    Nvidia lists the current driver for the Quadro FX 3800 as:
    Version: 311.50  Release Date: 2013.04.17
    http://www.nvidia.com/object/quadro-tesla-grid-win8-win7-winvista-64bi t-311.50-whql-driver.html
    May 1, 2013 10:46 PM   in reply to napynap
    I am having this EXACT same issue. But my system even tells me that the media files in my timeline are offline even if they are not.
    I also cannot export using hardware CUDA but only software. ( i have almost exact matching system specs )
    This all started out of the blue about 3 days ago.
    May 2, 2013 7:47 PM   in reply to napynap
    I have also updated the lastest drivers and have flushed the rendered preview files. This allows me to work for a while (30min or so) before locking up or losing the monitor but everything is VERY slow.
    The next step would be to roll back the video drivers to one of the older releases to see if that helps.
    Apr 11, 2014 9:35 AM   in reply to napynap
    For me, it was the use of warp stabilizer on my video clip....even though the effect was disabled in the video editor, i was also experiencing slow responsiveness. I just deleted the clip from the timeline, and brought back the same clip from the project window into the timeline- no fx applied-now there is no lagging at all. That's what worked for me.
Bookmarked By (1)
