How to cut a barcode
May 1, 2013 1:13 AM
Tags: #bar #code #barcode #scissors
This would seem rather simple - I'm looking to to take a supplied barcode and cut across it vertically to eliminate price information found on one side, the EAN5 portion which contains pricing. The barcode has its own white background border box which can be romoved, but I see now way to divide / cut apart the barcode. When clicking on it with the direct select tool, each line and number breaks down to separate outlines, but all elements reamin grouped together (though under "Object" they do show as grouped).
I've tried the more labourious method of selectively covering up portions of the code with the background colour - but these route seems unneccessary; I should be able to cut the object in half.
What to try?
    May 1, 2013 1:22 AM   in reply to luca del carlo
    Object Path>Release compound path
    May 1, 2013 1:24 AM   in reply to luca del carlo
    It must be a compound path, not a group.
    No need to release it into separate objects, though. You can use the white arrow to move individual points.
    May 1, 2013 2:51 AM   in reply to luca del carlo
    luca del carlo wrote:
    I don't quite follow - using the white arrow is allowing me to do things like bezier curves, but not select individual bars and numbers to delete.
    "Do" a bezier curve? The white arrow can be used to edit paths -- including deleting single points or entire sub-paths. Have you tried?
    Look, top-to-bottom: 'grouped' object; ungrouped, so now you can see it's two compound paths; some of the individual parts of the compound path deleted using the white arrow.
    The bottom image shows why I advise against Release Compound Path. Depending on how the image is constructed, after releasing you may not get the exact same image, even though these are the exact same paths.
    May 1, 2013 4:53 AM   in reply to luca del carlo
    Seems to me it would be simpler to just cut the barcode in its frame to the clipboard, then paste into a new frame and crop it.
    May 1, 2013 5:00 AM   in reply to Peter Spier
    .. I've been assuming this was native ID artwork because of Luca's assertion it can be ungrouped -- at least in a black foreground and a white background. My sample image is a barcode created with Marc Autret's EANDesign, which indeed creates native artwork.
    Luca, perhaps your image is something like an embedded EPS or EMF. In that case you are correct; you cannot edit these with InDesign. Then all you can do is use Peter's trick.
    May 1, 2013 5:14 AM   in reply to [Jongware]
    Even native artwork could be pasted into a new frame and cropped......
    May 1, 2013 9:54 AM   in reply to luca del carlo
    Actually, you don't even need to paste into a new frame if the barcode is a placed image of some sort. Just resize the frame it's in.
    May 2, 2013 4:11 AM   in reply to luca del carlo
    Resizing the frame as I've tried to convey, is not working as we are expecting. It results in changing the proportions of the barcode when using the black arrow (which would normally happen with the white arrow), and when using the white arrow, the frame can be removed, or the the lines and points stretched and altered, bu there is no way yet of cropping.
    This means youare dealing with either a compound path or a group of pasted path. Use the black arrow to select the entire barcode object, whatever it is, and cut to the clipboard. Switch to a the frame tool and draw a blank frame where the barcode belongs, use the black arrow to select it and Edit > Paste Into. Now you can crop.
    May 2, 2013 8:00 AM   in reply to Peter Spier
    Wouldn't it be better for them to work with the barcode in Illustrator?  That is what I would do.  Then when I had it cut apart the way I wanted it I would just copy the part that I was going to use and paste it into InDesign.
    Randy
    May 2, 2013 8:07 AM   in reply to The Digital Man
    That's a valid approach, if you have Illustrator and know how to do it. I prefer the paste-into-and crop for a couple of reasons, though. First, it's faster, and second it doesn't require you to do any editing on the barcode, so you can use it both ways without having to save two files.
