Multiple catalogues and missing images
May 1, 2013 5:51 AM
Tags: #elements_10_wayward.images
I have several overlapping catalogues in my elements 10. The largest is coordinated with the online backup (which is due to be terminated). It has over 400 missing images that cannot be reconnected via the online backup. Some of the wayward images may be in one of the other catalogues or a download to the external hard drive from the online backup (done last year).
1. How can I merge the several catalogues, and should I?
2. How do I serch the the file in the external hard drive? I.e., how do I designate this file in the "browse" dialogue box for where to reconnect? I can navigate to it, but then what?
Thanks in advance.
Dan F
    May 1, 2013 6:25 AM   in reply to DFredland
    Images are never stored in the catalog.
    There is no tool available to merge catalogs. The best you can do is to write the metadata to the files (File->Write Tags...) in each catalog, and then import all photos into a new catalog. In this process, you will lose albums and version sets and stacks and a few other things that I can't remember at this time. So, should you do this? If the drawbacks of the merge process don't make you say "Stop", then YES you should do this. I see no benefit, and huge amounts of confusion, caused by multiple catalogs, made even worse by the fact that they are overlapping.
    In PSE, you can find the name of the file, and this is the name you would use to search your hard disks using your operating system. Exactly how you do a search depends on your operating system, which you haven't mentioned.
    May 2, 2013 12:04 PM   in reply to DFredland
