billhercus
Blue Color Cast when Printing
May 1, 2013 9:27 AM
Tags: #photoshop #problem #color #canon #print #lr4
I have just carefully calibrated (again) my Canon Pro 9000 Mk11 Printer and Asus Pro Art screen using Spyder equipment.
Printing in LR4.4 consistently produces a blue cast.  I moved to Elements 11 and using the same just created profile printed the same picture/file.
No color cast.
I have LR5 Beta also so I printed same on it.  No color cast - to all intents and purposes identical to Elements 11.
'Perceptual' setting used throughout and no 'Print Adjustment' used in LR.
I am using Windows 8 64bit.
Why should LR4 only produce a color cast?  The settings have been carefully checked ...
    May 1, 2013 10:02 AM   in reply to billhercus
    Check your settings in the Canon Driver just to be double sure.
    May 1, 2013 10:06 AM   in reply to billhercus
    If you are using the same settings through out, as far as profiles, most likely something has gone a bit haywire with LR4. Try recreating the preference files for the application. Just delete or rename the old ones and let LR create new ones: http://helpx.adobe.com/lightroom/kb/preference-file-locations-lightroo m-4.html
    May 1, 2013 10:33 AM   in reply to billhercus
    And how is it set on the screen I showed?
    May 1, 2013 10:40 AM   in reply to billhercus
    Then what does your LR Print Job Panel look like in LR 4.4>
    Jul 11, 2013 12:06 AM   in reply to Brett N
    Hello:
    I'm not sure of site etiquite, whether I should ask another's advice about a separate problem, but my dilemma is so much like this and I have not been able to fix it on my own nor with Adobe or Epson's tech support.
    I too am getting out of my printer only prints that have a blue cast to them. My printer is an Epson r2000. I print from Lightroom 5 and Photoshop CS 6 or now its Creative Cloud equivalent. Yesterday, the i7 laptop I have been using for photo editing (with a better monitor attached) started producing only bluish prints--intended to be black and white (the max whites are white but everything else has a blue cast). It also was apparent in color prints when I tested that alternative. I was not too concerned because yesterday FedEx also delivered a gonzo new desktop computer that I had ordered just for photo editing. I thought, "Well, I'll install all my Adobe stuff there and migrate the Lightroom files and everything will be OK." But, immediately, the blue-cast problem showed up on the new computer. I thought I probably "migrated" the problem when I brought over my catalog, images and settings from the laptop.
    I reinstalled the newly installed printer driver and reinstalled the latests ICC files for the papers I use (Ilford Gold Fiber Silk and Gold Fiber Mono), but the problem persisted. I didn't yet know about blowing off the preset files.
    I spent a lot of time on the phone with Epson yesterday and chatted at length (1 hour 39 minutes) online with Adobe tech support today. Adobe had me do what you recommended--blow off the preset files and begin again, all to no avail. On my own, I again deleted and reinstalled the printer driver and wiped out the preset files.
    Still, I get a bluish overlay on my prints.
    After reading your posts, I meticulously checked my settings. Everything seems alright.
    I did one other thing. I printed images that had not been imported to lightroom in Windows Photo View through the same 13-inch Epson. They came out perfect.
    Now, I just don't know what to do next. Epson and Adobe support have done their apparent best. I live in a small town at the end of the Columbia River where I am looked upon as one of the computer problem solvers (a degree in Literature notwithstanding).
    I've thought of blowing off lightroom 5 and going back to version 4, but, as I understand it, that would mean losing all my metadata for some 40,000 images dating back to 1966, most of which I had to plug in by hand since they are from scanned negatives.
    Do you have any advice?
    I am a little anxious because I am supposed to have prints ready for a show opening on July 27.
    Thank you in advance for any advice you may offer.
    Paul
    Paul Haist
    Astoria, Oregon
    503-780-3379
    paulh@paulhaist.com
