Silly question but... I have CS6 and installed InDesign and Photoshop and Acrobat. Now I want to add Illustrator. Running "setup" it's not clear if I should check those 3 AND Illustrator or JUST Illustrator. If I only check Illustrator will it uninstall the others? If I check all 4 will it spend a bunch of time reinstalling the three that are already installed? Maybe overwritting settings?
Just check the one you wish to install. If it is going to uninstall anything, which is doubtful, it will prompt you before doing so.
You were right, but there was no way to tell that from the program interface.
Too often that's the case.
