AMC-AMC
combine supported files in acrobat missing in acrobat x pro when I right click drop down menu
May 1, 2013 6:38 PM
Tags: #missing_combine_supported
combine supported files in acrobat missing in adobe x pro when I right click drop down menu also Convert to Adobe PDF is missing too.  The open with & share with options are gone too when I right click files.  My computer crashed & I had to have the motherboard replaced.  The tech store put some of my programs back on my compter but not sure how or if they did stuff correctly.  Need help fixing my problem becasue I use this all the time.  Thanks
    May 3, 2013 10:57 AM   in reply to AMC-AMC
    Sorry to hear about the computer crash. Have you tried doing a Repair of the Acrobat installation from under the Help menu?
    May 20, 2013 8:31 AM   in reply to AMC-AMC
    I'm having the same issue. I got a new PC, insalled Acrobat X pro and when I right click on an Office file, I could not combine or convert Office files to PDF. I upgraded to Acrobat XI and still no fix. I triled to convert or combine office files to PDF from within Acrobat and I get an error message saying "Acrobat does not support the conversion of one or more of your files to PDF. Please remove these files or go to Settings and choose the PDF Portfolio option".
    I've tried to convert or combine Office 2003, 2007, 2010 and 2013 files and none work. The weird thing is that the option shows up for Excel .csv files. Even more werid is that I have the PDF tabs showing in the Office applications.
    I contacted Adobe support via chat and they were unable to help. I was directed here, so any help would be great.
    Thanks.
    Oct 21, 2013 3:40 PM   in reply to AMC-AMC
    I know you posted about this months ago but I'm curious if you ever got this problem solved?  I'm having the same issue and I want to pull my hair out!
    Oct 28, 2013 1:36 PM   in reply to AMC-AMC
    I have the same problem and yet to find a solution.  Help!
    Oct 28, 2013 1:39 PM   in reply to Rybak
    Bethtva and Rybak,
    I basically uninstalled the entire Office suite and reinstalled it (Office 2013) and it worked after that. Try that and hopefully that will resolve the issue.
