jbabertntn
Apparent cumulative error bug in Toolkit for CreateJS exporter.
May 2, 2013 1:18 PM
Tags: #error #cs6 #toolkit_for_createjs
Hello,
All the text in the .fla, original_swf_map.png, is one object, just_the_text.png.  When exported with Toolkit for CreateJS, there seems to be some error accumulating over the bits of text until some become quite far off from their original mark: generated_html_map.png.
I don't see this problem with simpler fla's of the same format, but it becomes apparent with one that's this large.  I could e-mail the generated .fla, but I'm not allowed to share it in a public forum.
    May 2, 2013 11:40 PM   in reply to jbabertntn
    Have you considered merging all your text in one bitmap-layer? Since you don`t seem to use code to fill in contents and are looking for pixel perfection this would be the obvious choice.
    May 3, 2013 5:42 AM   in reply to jbabertntn
    I ran some tests and this is what is causing your layout problems (probably)
    Internally Flash stores positions to a 0.05 pixel accuracy.
    But when exported to javascript via JSFL you end up with only 0.1 pixel accuracy.
    This is script that randomly places textfields on stage:
    import flash.text.TextField;
    for (var i:int=1;i<1000;i++){
    var tf:TextField=new TextField();
    tf.x = Math.random()*stage.stageWidth;
    tf.y = Math.random()*stage.stageHeight;
    tf.text = "tf"+i;
    addChild(tf);
    trace("tf.x:"+tf.x+"/tf.y:"+tf.y);
    in the output you see that flash actually "rounds" the positions to 0.05 pixel accuracy whereas javascript rounds that value even once more (to a .1 accuracy).
    This might be the loss you are feeling gets accumulated.
    May 15, 2013 2:24 PM   in reply to jbabertntn
    Are all texts left-aligned?
    I had a similar problem with right aligned text.
    In the latest Toolkit v1.2 that problem was solved.
    But only left-aligned texts are rotated ok.
    Mid- and right-aligned texts will get a displacement when rotated.
    May 16, 2013 5:42 AM   in reply to jbabertntn
    Sorry no. There is not really a site for Toolkit problems.
    ( <http://community.createjs.com/kb/faq/posting-guidelines>
    http://community.createjs.com/kb/faq/posting-guidelines)
    One difference between flash and CreateJs is, that the registry point is not
    used in runtime flash, but it is in CreateJs.
    So I guess it should be possible to get the correct rotations by the setting
    registry points of the texts.
    But left-aligning seems less work to me.
    Regards,
    Ronald
