balthaser
Do I use a number list or another method?
May 2, 2013 3:58 PM
Hello, I am very new to Indesign. I am working on a book project that is basically a two column layout. Every paragraph in the columns has a number prefixing it. To better understand what I mean, every paragraph is a verse and is numbered the same way the Bible has verses numbered in chapters.
Example:
1. Some sort of text would go here
and the words should also be
indented away from the number
and not flow beneath like you
you see here.
2. Then there would be more verses
that would appear in the same
manner all the way to the bottom
of the column.
So I have watched many videos and still cannot figure out what is the best method for this type of layout. Do I simply use a numbered list or is there a better way? I appreciate any advice.
Thank you,
Aaron.
    May 2, 2013 10:30 PM   in reply to balthaser
    If the text you are placing/writing is conducive to a numbered paragraph scheme, I would use it.
    Mike
