divyanshm7
How do I handle Style Groups in InDesign Scripting?
May 2, 2013 11:50 PM
Tags: #indesign #scripting
I am relatively new to InDesign scripting.
I'm trying to map Paragraph Styles to CSS, and it seemed to be working fine, till I came across Style Groups -
Styles belonging to a group are identified as - Root Style Group name : Child style group name : ...... : Style name
Because of this paragraph style  <Style name> was not mapping to the TOC style <Root Style Group name : Child style group name : ...... : Style name> and my TOC styles were not correctly mapping.
I wrote a fix for this in my app, by fetching parent groups and appending to a string - which i check in the TOC style entries.
Before calling this a FIX, I need to confirm if there are any more hierarchies/represnetations that could be used to represent a Paragraph Style as a TOC style? I don't want to see that a week later I discover something like <Style : Nested paragraph style> as a TOC style and then I'd have to fix my fix!
Thanks.
    May 3, 2013 3:51 AM   in reply to divyanshm7
    Moved from general discussions to the scripting forum...
    May 3, 2013 5:44 AM   in reply to divyanshm7
    If YourPara is a paragraph style in myDoc and defined inside group of styles named myStGroup
    you can refer to it using:
    myDoc.paragraphStyleGroups.item("myStGroup").paragraphStyles.item("YourPara");
    Jarek
    May 3, 2013 6:49 AM   in reply to divyanshm7
    TOC_style and para_style differ and you can not compare them.
    You could check if particular paraStyle is used as one of TOC_style or TOC_styleEntry properties, i.e.:
    tocStyle.titleStyle
    or
    tocStyleEntry.formatStyle
    A hierarchy of tocStyleEntries doesn't affect applied (used) paraStyle's names, I am preety sure.
    Jarek
