ares818
flash loop
May 3, 2013 11:47 AM
Tags: #flash
i made a flash video to drop into a website. it has 7 pictures that fade into each other. at the end - it does not go back to picture 1 properly. it shows picture 1, then skips to picture 6, then back to 1 and then starts over again. how do i make it a smooth continous loop ? thank you.
  • kglad
    Jul 21, 2002
    May 3, 2013 11:54 AM   in reply to ares818
    by default you'll have a continual consistant loop of the main timeline.
    you must be doing something (with actionscript or multiple timelines) to fail and display pictures in the same order each time your main timeline loops.
  • kglad
    Jul 21, 2002
    May 3, 2013 1:11 PM   in reply to ares818
    by default, your main timelin should play from frame 1 until its last frame and then return to frame 1 and continue until its last frame etc.
  • kglad
    Jul 21, 2002
    May 3, 2013 3:22 PM   in reply to ares818
    no, i don't.
    and neither can anyone else unless you explain what's causing that behavior or someone downloads your fla and explains the problem.
