iestudios
Can I see my logo displayed exactly as it is in Microsoft Word when converted to Adobe PDF?
May 3, 2013 1:03 PM
Tags: #word #pdf #to #logo #conversion
Here are two screenshots of the same document.  One is displayed in Microsoft Word (on the left), and the other is displayed in Acrobat after it's been converted to a PDF.
In Word, the IE logo has a faded look because it's in the header.  I want to keep this.  Also, if you'll notice the logo on the right, the white background behind the logo looks distorted and messy.....with faint lines all around it.  It's very faint here in this post, but if you look hard, you can definitely see it.  The Word document doesn't display those messy lines, and it also looks much crisper all-around.  Is there a way to adjust some settings within Adobe which would allow it to convert this logo more accurately?  Any help would be appreciated.
--Charles
    May 3, 2013 2:44 PM   in reply to iestudios
    The Fade look from Word is because the header/footer is not active, while typing in main body. When Printed it will be  the same look for body/header/footer.
    1. You can get that faded look but you will have to edit logo image file.
    2. Choose Format > Picture.
    3. Double click on it to bring up Format menu and the top item you can change transparency.
    4. Adjust for desired look, then get out of the format menu.
    5. and print a test page.
    6. If you see desired look then create your PDF
    May 4, 2013 7:50 PM   in reply to Phillip Jones
    You should be able to see the effect in WORD by doing a print preview. I could not see the lines you are talking about (may need to zoom in to get the point across). It may be an issue of using the Std job settings that reduce graphics to a lower resolution in many cases. You might try the press or print job settings.
    May 4, 2013 8:44 PM   in reply to Bill@VT
    Here is a Movie explaining what I am talking about: Adjust Transparency
    I used a Template I've created (a Letterhead) previously so I blurred out my address.
