Moving-Positioning Dig Tags
May 4, 2013 1:11 AM
Hello Dreamweaver's
A) I'm following along a tutorial and I'm also experimenting along the way how Dreamweaver treats various elements of the page. In this case Id like to know how can I have a gap in between the purple
and blue div tags, just for exercise purposes really,I don't know if its correct to do such a thing. But I'm trying to figure out the CSS on this issue.
B) and another question I have is, I have made a div tag 300 x 300
and when I type within DW if I don't do return/enter the type keeps
on going out side the boundaries box.
But if i copy/paste text within the box it positions it within the boundaries. why does DW do this?
heres the css:
body {
          background-color: #FFF;
          margin-right: auto;
          margin-left: auto;
          margin-top: 0px;
#footer {
          clear: both;
#content {
          background-color: #CCC;
          width: 900px;
          padding-bottom: 10px;
          margin: auto;
#aside {
          background-color: #00F;
          float: left;
          padding: 10px;
          color: #FFF;
          width: 500px;
body,td,th {
          font-family: "Lucida Sans Unicode", "Lucida Grande", sans-serif;
          color: #000;
#header {
          background-image: url(../_images/accent1.jpg);
          background-repeat: no-repeat;
          height: 120px;
          border-bottom-width: thin;
          border-bottom-style: solid;
          border-left-color: #333;
h1 {
          font-size: 250%;
          color: #FFFF00;
          text-align: center;
          margin-top: 0px;
h2 {
          color: #30F;
h3 {
          color: #30F;
h1,h2,h3,h4,h5,h6 {
          font-family: Verdana, Geneva, sans-serif;
a:link {
          color: #0F0;
          font-weight: bold;
          text-decoration: none;
a:visited {
          color: #0F3;
a:hover {
          color: #0C0;
          text-decoration: underline;
a:active {
          color: #0C6;
#article {
          background-color: #949;
          padding-right: 0px;
          margin-left: 0px;
          width: 500px;
          float: left;
#gallery {
          float: left;
          width: 0px;
    May 4, 2013 5:39 AM   in reply to inquestflash
    We need to see the HTML in order to know how the CSS is applied.
    Chris
  • Sudarshan Thiagarajan
    Oct 15, 2010
    May 4, 2013 7:20 AM   in reply to inquestflash
    'article' and 'aside' are both HTML5 native tags itself - I dont see why you should use those names within a div. Aside is usually used when it contains some content relevant to a container into which it is placed in. In your case, a simple div with margin should do the trick.
    To ensure you dont get confused, I'm using your existing HTML code here. You have 2 boxes - one with ID aside and other with ID article. You could simply add margin-left to article or margin-right to aside and/ or padding to both in CSS:
    CSS margin-left to right hand side box:
    #article{
    margin-left: 20px; /*Gives you 20px margin on left before starting the right box*/
    #aside{
    margin-right: 20px; /*Gives you 20px margin on right before finishing the left box*/
    And to push the content within these 2 boxes a little inside on all sides:
    #aside, #article{
    padding: 20px; /*Pushes content inside the boxes by 20px on all 4 sides*/
    Oct 15, 2010
    May 4, 2013 10:13 PM   in reply to inquestflash
    inquestflash wrote:
    Hi, Surdarshan thanks for those tips. worked well. I dindt know you can nest css within another css rule.
    I have not reached that far.
    No, you're not nesting CSS within CSS. CSS is a cascading stylesheet file. IDs and classes can be targeted by using CSS. General page styling is also targeted using CSS. Anything in your CSS starting with # is a div ID and with . is a div class. IDs can only be used once in each page - they're unique. Classes can be used any number of times on 1 page.
    You can create a CSS rule like this for all paragraphs:
    p{
    color: #000;
    This will make all <p> text black on your page. This is because p itself is a HTML tag that you can define attributes for.
    Similarly, you 'aside' and 'article' in itself are HTML5 tags that you can define in general like this:
    aside{
    padding: 10px;
    This will give 10px padding to all 'aside' elements on your page. In this instance, you can simply write your HTML as:
    <aside>Some content here</aside>
    The content within this will have 10px padding.
    If you have lets say, 10 such <aside> content on your page and want to only give specific rules for 1 of them, you can create an ID for that and write a specific CSS for it like this:
    <aside id="orange">Some content here</aside>
    You can write specific CSS for this aside like this:
    aside#orange{
    color: #ff9e00;
    This will make the content within aside id orange as orange.
    Instead of #, if you use . you can re-use that class in multiple aside tags by replacing <aside id..> with <aside class..>
    You can definitely name your classes or IDs 'article' or 'aside'. But, I just think that would be redundant as these in itself are HTML markup tags.
    For centering your content on the webpage, use on the parent (main) container:
    margin: 0 auto;
    Good luck!
Bookmarked By (1)
