Creating outlined text using filters
May 5, 2013 10:17 AM
Tags: #text #to #filters #applying
About a month ago I was experimenting with applying filters to text. I managed to make the background black and the text converted to a white outline. I believe I did it using artistic/watercolor. I made a series of five images using this process and now I can't recreate the effect. I definitely did not use strokes or any of the other common ways of creating outline text: It was really quite accidental and done entirely with filters. Below is a sample. Any idea how to recreate this?sample.jpg
    May 5, 2013 10:26 AM   in reply to dg2727
    Find Edges and then inverting might work.
    If I may ask: Why do you want to do something with a Filter that might more easily be done with Layer Styles?
    And if I may add: Why did you not use a Smart Filter?
    May 5, 2013 10:34 AM   in reply to dg2727
    I really do not care how I do it as long as I can create the same effect.
    Well, Layer Styles would offer benefits in that regard as Styles can be saved with and applied from the Layers Panel.
    May 5, 2013 10:58 AM   in reply to dg2727
    Was the layer black text on a white background?
    (the text and white background on the same layer)
    If so, you might try setting the tool box swatches to the default colors.
    (press D on the keyboard)
    Then try Filter>Artistic>Neon Glow with the Glow Color set to white.
    May 5, 2013 11:24 AM   in reply to dg2727
    May 5, 2013 11:40 AM   in reply to dg2727
    text color does not matter.
    outline color is the color of stroke effect.
    background color any you want.
    ps. hope you understand my english
    May 5, 2013 10:59 PM   in reply to dg2727
    Used the stroke tool.
    Stroke is not called a Tool in Photoshop, it is called a Layer Style.
    As for »Find Edges«: To get the result you would have to filter background and text together.
