cs6 - crashes when searching all files in site
May 5, 2013 4:40 PM
DW crashes everytime I search all files in the site.
I have tried:
  • uninstall/reinstall
  • resetting configuration and preferences
  • installing latest updates
I CANNOT use DW under these conditions!   Please help!  I'm on: version 12.2.v 6006
  • Sudarshan Thiagarajan
    Oct 15, 2010
    May 5, 2013 9:40 PM   in reply to joeyblowie123
    Does this happen only with 1 site or all sites within DW? If it is only on 1 site, have you defined your site properly?
    Can you try trashing your cache to see if that helps: http://forums.adobe.com/thread/494811
    Oct 15, 2010
    May 7, 2013 6:56 AM   in reply to joeyblowie123
    Can you double, triple check your site definition settings to ensure they're all intact and the way its supposed to be?
    Go to Site > Advanced > Recreate Site Cache to let DW recreate a cache for your site and then try to see if it persists.
    Oct 15, 2010
    May 7, 2013 7:25 PM   in reply to joeyblowie123
    Not the 'enable cache' in advanced tab.
    My reply #4 was on the main Dreamweaver menu bar where you see File, Edit, etc... There, click on 'Site' then click on 'Advanced' and hit 'Recreate Site Cache'.
    Oct 15, 2010
    May 7, 2013 10:41 PM   in reply to joeyblowie123
    So it worked 3 times. Then there's nothing wrong with your site definition/ config.
    When you say it 'crashed' the 4th time, do you see a crash report/ error log that you can copy & paste here for us to review?
    Also, does your site have any files that are read from a local network/ web server?
    Oct 15, 2010
    May 8, 2013 1:28 AM   in reply to joeyblowie123
    Sounds good. Also, ensure that you've installed all available updates to DW. From the main menubar, Help > Updates to check, download & install all available updates.
