IRISccg
How to import repeated data cells with XML?
May 6, 2013 7:01 AM
Hello!
I have some little troubles with the XML import functionality.
Let's consider a billing table:
ItemPrice
Tax percentageVATTotal price
Item description$8020%$20$100
Total$80
$20$100
    May 6, 2013 7:07 AM   in reply to IRISccg
    What trouble are you having? Your post doesn't identify what the issue is.
    If you want to see what your XML source should be structured like, create a table, add the appropriate data, and export it as XML. Open it in a text editor. Make your output from however the data is generated be like it.
    Take care, Mike
    May 6, 2013 7:30 AM   in reply to IRISccg
    Yes, the forum software I love to hate...
    Hmm, haven't seen a repeat unless the XML data is malformed. And it appears in the screen shot that a table is inserted into a table? (Well, both repeats appear to be tables in tables).
    In a new document, I would begin with creating the data as per your first screen shot (if that is how you want the data), export to XML and compare it to a single node in your imported XML. Cause it looks like unclosed or repeated data.
    Mike
    May 6, 2013 8:44 AM   in reply to IRISccg
    I quickly modified an existing XML I am working on. Try this.
    <Prices>
    <table>
    <tgroup cols="4">
    <colspec colname="1"/>
    <colspec colname="2"/>
    <colspec colname="3"/>
    <colspec colname="4"/>
    <thead>
    <row>
    <entry>Item</entry>
    <entry>Price</entry>
    <entry>Tax</entry>
    <entry>Total</entry>
    </row>
    </thead>
    <tbody>
    <row>
    <entry>Item 1</entry>
    <entry>Price 1</entry>
    <entry>Tax 1</entry>
    <entry>Total 1</entry>
    </row>
    <row>
    <entry>Item 2</entry>
    <entry>Price 2</entry>
    <entry>Tax 2</entry>
    <entry>Total 2</entry>
    </row>
    <row>
    <entry>Item 3</entry>
    <entry>Price 3</entry>
    <entry>Tax 3</entry>
    <entry>Total 3</entry>
    </row>
    </tbody>
    </tgroup>
    </table>
    </Prices>
    May 6, 2013 11:58 AM   in reply to IRISccg
    I'm not thinking there is a bug, but rather a communication error between what you write and what I think it means. If you needed a different structure, it would have been good to know exactly how you wish for the import to lay out as.
    In the end, glad you worked it out.
    Mike
